RC Vehicles Discussion on remote controlled vehicles of all types
RC crawler guys - thinking about getting into the hobby
Old 12-02-2011, 04:20 PM
  #181
iamsuperbleeder's Avatar
Fink, the SCX-10 RTR comes with Tamiya battery connectors
while they do get the job done, I had problems with mine coming loose and I would randomly loose power after only having the truck for about a week. Deans have a spring on one side of the pins on the connectors, so when you plug them together there's a physical force holding the pins together, unlike the Tamiya connectors that basically just slide into one another, and the plastic outter part of the connector is what holds the two ends together
you can see the spring pretty good on the side of the pin in this photo
and Corey, that's a creepy avatar
Old 12-03-2011, 07:31 PM
  #182
Fink's Avatar
Thanks for the info Travis!
Looks like I'll either need to get an adapter or just swap the connectors out on both the battery and the truck.
Would a case of beer be enough to talk you into doing it for me?
Is it difficult to swap the Tamiya connectors over to Deans? I haven't soldered in a long time, and will need to go buy one...
I ended up getting two Gens Ace 5000mAh 40C 2S1P (Direct Version) batteries and the Thunder AC680 charger. Two batteries and a charger for right around $110 - way better than I was expecting.
Truck should be here on the 7th, and the batteries/charger will probably be here on Friday.
Fink
Old 12-04-2011, 04:24 PM
  #183
SoCal4Running's Avatar
Are you guys using the 5000Mah for weight?
Seems like a huge battery for a crawler.
I get a good 45 minuets of crawling out of my 2200Mah
Old 12-04-2011, 04:29 PM
  #184
lol, it aint no thang, I'll solder them bad boys on for nothing but I need to get a new tip for my iron first... it's all but completely burnt up, lol. you could probably pick up a Tamiya to Deans adapter from a local shop in the mean time to get you by, but I wouldn't consider it a permanent fix since the Tamiya connectors are still on it and can still cause issues...
and it is a large capacity battery, BUT, that thing will have you wheeling for HOURS without having to stop and change batteries or worrying about charging it. the only bad thing about such long run times is that you often get bored before the stupid thing dies unless you break something, but that's a different story
Old 12-06-2011, 12:58 PM
  #185
Fink's Avatar
Fink
Old 12-06-2011, 01:01 PM
  #186
Fink's Avatar
I wanted to get a battery that I wouldn't worry about completely discharging while running the truck, and that I could also use in other cars/trucks as I get them.
We'll see how I like them. I may end up getting some super cheap ones that I can just use and not worry about.
I just hope I don't catch anything on fire while charging them...
Fink
Old 12-06-2011, 01:53 PM
  #187
Co-Founder/Administrator
Staff
Corey's Avatar
Cut the box OPEN NOW
My charger has a two hour cutoff on it.
The battery takes almost that long to balance charge it from zero.
If your charger has a cutoff on it, you should be fine with no LIPO explosions or fires.
Old 12-16-2011, 12:57 PM
  #188
Fink's Avatar
Still haven't even had time to open the boxes yet! :angry:
I did find this sweet video of a Toyota-themed Wraith...
http://youtu.be/mH2VN1OT0O4
Fink
Old 12-16-2011, 02:57 PM
  #189
how do you have enough time to browse YouTube but not enough to cut open a box?
as long as you charge at the correct amperage and voltage, you should have to worry about any fires unless the battery gets physically damaged
Old 12-16-2011, 05:12 PM
  #190
SCToy's Avatar
that is freakin awesome Fink!
Old 12-16-2011, 07:47 PM
  #191
None of these are mine but are awesome vids
http://www.youtube.com/watch?v=HkvY47llYdk
http://www.youtube.com/watch?v=drdIa..._order&list=UL
http://www.youtube.com/watch?v=ruBFX..._order&list=UL
One more below
http://vimeo.com/30163924
Old 12-19-2011, 08:27 AM
  #192
Bassinfool's Avatar
Ugh you guys are making me want one of these! Like I need something else to spend money I don't have on!!!
Old 01-03-2012, 05:06 PM
  #193
well guys, I went ahead and sold my SCX10 that I use to have so much fun with...
it's been sitting on the shelf for a month now not getting any attention, and I'm having a little more fun with the fast RC's
it sold today and I'll be shipping it out to it's new owner in Pa tomorrow
the funds from it's sale will go towards one of these
Old 01-03-2012, 08:37 PM
  #194
4WD Slash!!!
Go 3s or go home
Old 01-03-2012, 10:04 PM
  #195
Originally Posted by SoCal4Running
4WD Slash!!!
Go 3s or go home
3s?
psh, I plan on throwing a Mamba on it and running 6s
Old 01-04-2012, 05:20 PM
  #196
Oh.....well that'll work too
Old 01-08-2012, 09:49 AM
  #197
Video I made at a local hidden crawl spot.
http://www.youtube.com/watch?v=X9I8IHSPi_s
Watch in HD, was filmed with GoPro Hero 2
Old 02-12-2012, 01:12 PM
  #198
Fink's Avatar
Got my hobby room somewhat put together.
$45 table from IKEA and a banquet table from work for free - not 100% happy with it so far. My self-diagnosed OCD is making me want to get matching tables in there. We'll see what I end up doing.
I have an E-Maxx, T-Maxx and RC10TC3 out in the garage that I need blow off with the compressor before I bring them in - they will go on the shelving unit with the SCX10 and Blitz.
Fink
Old 02-16-2012, 09:18 PM
  #199
I wish I had that much work space
I've been banned from the living room coffee table and the kitchen table, LOL
Old 04-01-2013, 11:50 AM
  #200
Staff
Corey's Avatar
Check out this video that was just uploaded to my YouTube subscriptions.
06-01-2021 01:51 PM
Road Bull
10-10-2015 04:55 PM
skoti89
07-08-2015 12:05 AM
timmJ
07-07-2015 02:01 PM
karbin
07-05-2015 11:37 PM
Quick Reply: RC crawler guys - thinking about getting into the hobby
