FJ40 Frame Boxing Kit.....!
Old 06-28-2012, 10:29 AM
FormerVendor
Gravel Maker's Avatar
Thumbs up FJ40 Frame Boxing Kit.....!
These are Reinforcement Plates to box the rear of your FJ40, they are .1875" (3/16) thick Steel Plate. Made to strengthen an inherently weak area on an FJ40, opinions differ on whether or not Boxing the frame should be done so do your research. We believe the frame should be stiff and the suspension should be doing the flexing. Flexing the frame loosens the rivets and slowly tears it apart. This comes with a 1.75" x .120" replacement crossmember with 4 predrilled placement options, one of the holes is at the stock position and the others are spaced 3" on center, one in front and 2 behind the stock position. If you are adjusting your WB way back we would recomend 2 Crossmembers to retain the structural rigidity gained by the frame boxing itself and the Crossmembers provided are long enough to allow mounting through the existing frame also (just drill 1.75" holes through the frame using the Plates as a guide). These are designed to fit within the frame itself so you do not have to remove the tub to install, however you do have to remove the factory Crossmember and mounting plate and reposition the rear brake line. The short angled plates are made 1/8" long to allow for movement that has already occured. Welding Required!
This is really a pretty simple kit, I will add a couple of good pics of one on a frame ASAP......
http://www.ruffstuffspecialties.com/...FJ-BOXKIT.html
Old 07-18-2012, 10:38 AM
FormerVendor
This kit really does make things easy.
Old 08-08-2012, 10:44 AM
FormerVendor
Arrow FJ40 Frame Boxing Kit.....!
Looks great.. Adds tons of strength to your factory frame !!
Old 08-28-2012, 09:38 AM
FormerVendor
A lil work now will save a lot of work later on !!
Old 09-26-2012, 09:25 AM
FormerVendor
A solid way to upgrade !!
Old 07-13-2013, 11:50 AM
FormerVendor
Do it right the first time!
Old 11-14-2013, 11:21 AM
FormerVendor
Not many people offer this if any, so take advantage of it!
Old 11-12-2014, 07:54 AM
FormerVendor
What an extremely busy week!
JustMike
04-21-2016 07:08 PM
Jcrawl94
10
10-24-2015 04:34 PM
4x4-runner
08-30-2015 08:55 AM
YOTATOY403
08-06-2015 12:00 PM
4x4-runner
08-02-2015 09:24 AM
Quick Reply: FJ40 Frame Boxing Kit.....!
