New HD Chromoly Rear Axle Shafts at Marlin Crawler
Old 04-30-2012, 02:15 PM
BigMike's Avatar
We are now carrying Yukon's new Heavy Duty 4340 Chromoly Rear Axle Shafts! These axle shafts are dual heat treated for maximum strength and feature 30% stronger cold rolled splines.
The result is a full warranty against axle breakage for as long as you own your rig.
Applications include all 1986-2004 rear Pickup/4Runner/Tacoma rear ends, with or without ABS. This is possible thanks to Yukon's cut-to-length design. Yukon has used this design for many years on domestic applications and has finally incorporated it for Toyota's! Simply measure your old axles, cut the new axle to length using a chop saw, and then bevel the splines with a bench grinder. This process does not affect the axle's performance because the cut is beyond the side gear where no contact is made.
Yukon Heavy Duty 4340 cut-to-length axles are so reliable they are used in large diesel drag racing applications! Put this same performance to work for your Rock Crawling needs today!
Product Link: http://www.marlincrawler.com/axle/re...oly-rear-axles
Regards,
BigMike
Old 04-04-2013, 05:24 PM
BigMike's Avatar
Trim-to-fit in four easy steps!
1) Measure the length of your stock axle
2) Cut
3) Bevel
4) Install!
As you can see, the final cut is very similar to a stock axle, and as mentioned above, the process does not affect the axle's performance because the cut is beyond the side gear where no contact is made.
Click here for more details: http://www.marlincrawler.com/axle/re...oly-rear-axles
(Cutting shields removed in the above image for illustration only. Always wear safety glasses!)
A2theK
01-10-2016 10:18 AM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: New HD Chromoly Rear Axle Shafts at Marlin Crawler
