Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
5 spd transmission shifter housing 22re 2wd. help!!
Old 12-06-2011, 07:27 AM
dlock30's Avatar
Newbie here, and first time owner. Well I bought a toyota with a bad transmission so I replaced it. The shifter housing was different then the one that I had so I had to take off the rear case to the transmission and swap it. My question is how do I put the rear casing back on the transmission and align the shifter fork so I can shift?
Old 01-19-2020, 12:36 PM
Papadeath's Avatar
Trans assembly
Everything should mate up as you slide the rear casing on and bolt it up, if the bolt holes don't line up they're not compatible. I'm assuming you have the W55 trans? Is this a new or used trans? If its used always replace the shifter bushings and rear seal. I've also found that the internal shifter boot likes to leak oil so I use a little the right stuff gasket maker by permatex, one minute set time but actually its a little longer but its good stuff. Expensive but good. Without knowing specifically what problem You're running into its hard to help but may be these tips will get you on your way.
Blake Cascio
12-26-2016 11:27 PM
Phessor
12-02-2010 07:13 PM
chaz97x4x4
08-04-2010 06:34 PM
STINGRAY7574
03-05-2009 01:56 PM
Quick Reply: 5 spd transmission shifter housing 22re 2wd. help!!
