Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
4x4 Rear End Questions
Old 07-14-2011, 06:00 PM
rockcs8588's Avatar
Anyone know anything about Toyota rear ends? I have a 1988 2wd and I'm pretty sure i have a 7.5 rear end on this truck since it was the most common for this year and i was planing on doing an LSD/gear job on it but if there is a rear end out there that has LSD stock maybe the 4x4, 8 inch rear end idk...it would be nice is someone can enlighten me b/c i cant find much on rear ends anywhere just numbers nothing about LSD. reason why i ask is b'/c i plan on doing a desert truck build and i don't want to be in the dunes with a peg leg..So my questions are : Is the 4x4 8 inch rear end lsd? (it most likely is hence the meaning of 4x4 but just to clarify) and can i swap it over to my 2wd?
any info is much appreciated.
Old 07-14-2011, 06:28 PM
scuba's Avatar
Sounds like you could use the supra 7.5" LSD.
Old 07-14-2011, 06:45 PM
rockcs8588's Avatar
yea i was looking into that but so far its all for 8 inch rear ends out of a 4x4 also turbo supras are hard to find in wrecking yards
Old 12-19-2012, 04:27 PM
CJ94yota's Avatar
How do you decode the gear ratio code on the Vin sticker in the door jam ???
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Quick Reply: 4x4 Rear End Questions
