Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
2wd lift options thread
Old 08-11-2014, 10:12 PM
  #41
Robert m's Avatar
The cheaper procomp 1000 and 3000 series shocks are not charged. I had the 3000s on my truck but I hated the way they rode. You could also give http://www.doetsch-shocks.com/ a try
Old 04-17-2016, 05:57 PM
  #42
J'villeTaco's Avatar
Anybody using the Maxtrac 4" spindles up front with billies? If so, would the AllPro expedition springs be too much in the rear? Planning to add a tool box so there will be a little weight in the bed. Thanks...
Old 04-17-2016, 09:32 PM
  #43
Robert m's Avatar
Never heard of them. Doing a quick search, do they even make lift spindles for the pickups or just for tacomas? Parts are not compatible between the two.
Old 04-18-2016, 02:55 AM
  #44
I purchased a set from Headstrong Offroad but there still in the box. Need a little more $ to get a few more parts for the lift... Here's some info on them.
http://www.headstrongoffroad.com/max...05-tacoma.html
Old 04-18-2016, 01:06 PM
  #45
Robert m's Avatar
Ok, so you're asking about a tacoma prerunner. This thread is for 84-95 2wd pickups. You would probably get a better responses if you made your own thread.
Old 04-13-2017, 05:22 AM
  #46
Philip84's Avatar
Seems like Fabtech is stocking their lift kits again: http://www.fabtechmotorsports.com/TOYOTA-2WD/PICKUP-5-LUG-1984-95/3-5-quot-SYSTEMS-c1364/
Old 04-17-2017, 01:37 PM
  #47
Philip84's Avatar
If anyone's still reading this sticky, I know used upper control arms aren't difficult to find. My question is are there any non-aftermarket UCLs that will do the same job as the Fabtech ones?
Old 11-20-2021, 12:59 AM
  #48
Pri$erulz's Avatar
Maybe this is dumb...
Maybe this is a dumb question but is it possible to install a pre-runners suspension onto a 1984 2wd pickup? I am digging into lifting my 2wd and want something simple. The original idea was to turn up the torsion bars and buy longer shackles to get about 1" of lift but I am starting to think the torsion bar method is not the best method.
Old 12-13-2022, 07:24 AM
  #49
semcoinc's Avatar
Add-A-Leaf to Spring Pack
For my saggy a$$ rear end on ~200K mile original leafs that I beat up this year hauling over gross weights of concrete and asphalt I installed ProComp Add-A-Leaf kit #13120 which got me about a 2" rear lift and put me just a little higher than the stock front end.
While I was at it I changed the leaf spring bushings. A much smoother ride was noticed with the new bushings.
I started with a rear fender height of 27.5" and ended with a height of 29.75"
This was a beast of a project for me, even with some YouTube help. The order of operations of putting the leaf pack back into their mounts is critical. I found that you mount the relaxed/unbolted spring pack into their mounts THEN clamp them up and tighten the center bolt. Then you align the center bolt with the axle spring perch, then bolt up the bottom saddle.
The picture showing the leaf pack bolted together before mounting did not work for me.
Also, had to employ a "Redneck" shackle press using the factory screw jack and a custom length of 2x4 to press out the driver side shackle which was not cooperating with my BFH and I was concerned about damaging the threaded shaft with continued BFH blows.
PS: A proper Class III hitch was installed after the bumper mount was abused.
Mike
Benson X
03+ 4Runner/GX470, & 05+ Tacomas (Build-Up Section)
09-30-2013 11:28 AM
TRUCKDIVA
Vendor Advertising
07-12-2013 11:36 AM
TRUCKDIVA
Vendor Advertising
06-18-2013 12:28 PM
SEMSD
04-22-2009 06:07 PM
Quick Reply: 2wd lift options thread
