Looking For A Mechanic/Fabricator/Shop Put your location in your thread title when making an inquiry
3VZE rebuilder needed
Old 10-31-2012, 07:59 AM
yodal's Avatar
My 94 Runner V6 motor died, looks like the crank broke at the journal by the flywheel.
I need suggestions on which builder to get a long block from.
How about these builders?
http://yotashop.com/
http://www.rebuilt-auto-engines.com/...31112225884.5d
http://www.japanengine.com/products/...0&search=&page=
http://www.toyotacarpart.com/default.asp?p=8
http://oregonengines.net/home.nxg
Old 10-31-2012, 09:20 AM
Abe1337's Avatar
Try Putneys: http://www.putneyscustommachine.com/...20Machine.html
Jim is a really nice fellow. He's building me a new 3vze right now as I type this. I had to eat a loss from a rebuilder that you linked up. Garbage motor. Don't be fooled by unlimited lifetime warranties. With some of these rebuilders it means having to pull your motor all the time because it doesn't work right.
Good luck with your project!
Old 10-31-2012, 06:07 PM
TNRabbit's Avatar
What did you do to break a crank??? They are darned robust...
Old 10-31-2012, 06:46 PM
yodal's Avatar
I think the motor was a crap rebuild. I bought the runner 3 years ago and the guy said he had a buddy rebuild it. I got 26k out of it. It started making a slight clicking noise like some kind of light weight sheet metal slapping something, then at the stop light taking off BOOM done! No hole in the case though???
Old 11-01-2012, 03:25 AM
iselloil's Avatar
http://www.sunwestautomotiveengines.com/lb-toyota.html
Old 11-02-2012, 07:25 PM
yodal's Avatar
I spoke with Mike twice this week (http://www.sunwestautomotiveengines.com) and most certainly will be ordering the motor on Monday. The details of what they do versus what some of the others do sounds like a solid motor.
Two of the other companies only sand the head, sand the surface on the block that the heads mate to, put sleeves in the valve guides (don't actually replace the guides and seals) and don't replace the freeze plugs unless they show leakage. I'm sure there were other things that I wouldn't like but these items scared me off. There is a $700 dollar difference but I really like my runner.
Plus Sunwest also includes more items on the long block (these items are just a bonus in my mind).
Old 11-03-2012, 01:46 AM
wyoming9's Avatar
Red face
If your mind is all ready made up Good Luck!!
I would not spend a nickel on a 3.0.
I would just go 3.4 but to each there own.
Old 11-04-2012, 05:20 AM
yodal's Avatar
If I had the time, space and money I would. Next option is now on the table. Thanks for your thoughts.
Old 11-04-2012, 09:04 AM
BMcEL's Avatar
If you have the time, space, and money to pull and rebuild a 3vz, you have the time, space, and money to swap in a 5vz.
Old 11-04-2012, 11:15 AM
yodal's Avatar
Someone else is doing it for me at his shop. He as well as two other shops arn't interested in doing the swap for me.
Old 11-04-2012, 04:05 PM
yodal's Avatar
Maybe I'm missing something. From what I've seen you need to find a 5VZ motor, a trans that matches it (I suspect from the same vehicle the 5vz came from) and gotta do some rewiring.
I'd like to have this in my runner. Any suggestions on people doing this for someone in Colorado?
Old 11-04-2012, 06:30 PM
SeeBeeAre's Avatar
I used Oregon Engine re builders cause of there life time warentee. Pacific machine has a 7 yr..... I was super happy with Oregon wish I would have gone with there superstock
Old 11-05-2012, 12:31 PM
yodal's Avatar
I think I owe Wyoming9 and BMcEL a thank you. After seeing both of your post I started searching more and finally found someone with experience in the swap. Gonna have it all done in about 3 weeks from now.
Thanks
Old 11-09-2012, 03:37 PM
clocklaw's Avatar
This was my 3.0 purchased from toyotacarpart.com a.k.a. APR Autocare - 2450 East Platte Avenue - Colorado Springs, Colorado 80909 after 15,000 miles:
Old 11-10-2012, 03:23 AM
yodal's Avatar
I visited toyotacarpart.com a.k.a. APR Autocare - 2450 East Platte Avenue - Colorado Springs, Colorado 80909 shop and they showed me some of their procedures.
They were nice people but there processes scared me away. Sorry your having a crappy experience with them.
Old 08-04-2013, 01:13 PM
clocklaw's Avatar
Well, after letting this albatross sit for over a year, we decided to dig into it and see what it would take to get it going. Looks like the block surface (not the heads) is out of spec between the two cylinders that failed.....so the block is toast. $%#$@#%^$#@
Failure is between cyl 3 and 5
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
BigArt70
06-30-2015 09:51 PM
HALMAN
06-14-2002 09:02 PM
Quick Reply: 3VZE rebuilder needed
