93-98 T100s (Build-Up Section) Post your build-ups here
1996 t100 4x4 work in progress
Old 04-26-2012, 05:34 PM
Zpd426's Avatar
Well I only need about 5 inches of vertical space, Im thinking of using 2 inch square bar. I want to keep the mount small so I can still use the bed. Planning on using 11.5 inch travel internal bypass shocks off a Raptor. With Deaver mini pack. I really wont know what it will look like until I do it.
Old 04-28-2012, 08:58 PM
Zpd426's Avatar
Went to texas canyon today aka Rowher flats. Really put the kit through the ringer, Gnarly LONG STEEP ROCKY hill climbs kept awesome traction, NO way could I have gotten to the top with stock suspension!
Here are some pics
Old 05-06-2012, 06:50 PM
Bass_rodder's Avatar
Im about to make a similar tube bumper for my 1995 t100. Your looks great, and was wondering if you would be willing to share the dimmensions?
Old 05-06-2012, 07:01 PM
Zpd426's Avatar
Sure, Its a old smittybilt. What dimensions do you need?
Old 05-07-2012, 07:39 AM
  #25
how long the different sections between the bends are, and the radius and angle of bends if possible. thanks
Old 05-11-2012, 09:45 PM
  #26
Zpd426's Avatar
Just added a Hood snorkel.
Old 05-11-2012, 09:48 PM
  #27
Zpd426's Avatar
Old 05-11-2012, 09:55 PM
  #28
Zpd426's Avatar
Not a good angle to see the steep rocky part of course but you get the idea it climbs high in no distance. Hope you enjoy the photos!
Old 05-12-2012, 04:41 PM
  #29
ToyoTech559's Avatar
nice t100. not too may people build these up and you have LT. i plan on getting LT soon since my upper control arm bushing are shot and figure it be a good time to go LT
Old 05-12-2012, 07:11 PM
  #30
rockroller's Avatar
hey truck looks good
i dig the front bumper too
im guessing you have the trailer hich up front for a removeable winch?
am wanting to do the same i have a 93 t100 reg cab
also about your locking hubs are they worth it ? do the t00s need them?
thanks
Old 05-12-2012, 07:38 PM
  #31
Zpd426's Avatar
Thanks, Yea I love the LT totally worth it.
Old 05-12-2012, 07:42 PM
  #32
Zpd426's Avatar
thanks
I actually just cut all of that stuff off the front because it weighed a ton, I dont actually have a winch but It was wired for one and set up to be flat towed behind our old motorhome.
I went to the locking hubs because I wore out my front driveshaft Twice. Im not sure if that is because of my trutrac up front or not, But I recommend the hubs. You dont want all of your front driveline spinning all the time. Again not sure if all auto hub t100s spin when not in 4x4 but mine did.
Old 05-12-2012, 08:59 PM
  #33
rockroller's Avatar
humm ya the 4x4 drive is auto on mine shift on the fly but think the t100 use ADD something to do with the vsc i think in the front gears
i found a 4 rider with asisn manal hubs so been wounldering if they would work for the t100 as for new locking hubs here cost 350 from warn
im guessing that if i do the hubs it will stop the cv from moving and wear and tear on them
just got to lock them im the winter and still can use the shift on the fly
Old 05-29-2012, 09:24 PM
  #34
cr@ves4wheelin's Avatar
Gotta love the T100s with LT, looks great man.
Old 06-04-2012, 08:38 PM
  #35
Zpd426's Avatar
Here is how I did the snorkel.
First I removed the old tube and mount from the fender, plugged the stock intake with a solid washer and siliconed It in.
2nd I used a 3 inch hole saw and cut a new hole in the stock airbox.
3rd I used a pvc coupler wrapped in a rubber coupler and trimmed the hole for a tight fit, then siliconed that in.
4th I cut a hole in the hood using a 3.5 hole saw designed for metal.
5th I mounted another pvc coupler wrapped in a rubber tape untill it became the right size. To the underside of my hood RE-utilizing The stock intake mount on the inside of the fender using sheet metal screws and something to act as a nut plate.
I had to use about a half inch of spacers to get the mount at the right angle so the snorkel went straight up.
And last I used a slinky like expanding intake hose so when i open the hood it expands and when I close the hood I guide it back down straight.
I need to cut some fuel line and circle it around the opening to make it a little cleaner. I have metal particles stuck the adhesive from the tape I used.... Excuse my dirt. just got back from a outing.
Snorkel and A new k&n replacement filter gave me a good amount more power and faster revs.
Total cost $25 for snorkel off ebay
$25 for hose off ebay
$20 for couplers etc.
$45 for K&N replacement filter
$20 for hole saws
Old 06-04-2012, 08:55 PM
  #36
rockroller's Avatar
looks good dude so faster revs? i know the 3.0 slow needs that it sucks down shifing to 3rd gear going up hills i wonder if it will work for me too
Old 06-04-2012, 09:39 PM
  #37
my experience with driving into water at speeds is the water splashing up and on top of the hood. i guess you could always turn your snorkel head to face the other way when the time comes. oh btw i just got my LT installed and got about 100 miles on it.
Old 06-05-2012, 12:00 AM
  #38
Zpd426's Avatar
My truck still down shifts to third on big hills if I don't get a chance to gain momentum, like in traffic. It will help but only so much.
Ya that's the only drawback. But I just came back from a trip that would have snatched off my snorkel from the top if I had it there.. more often its trees rather than water. At some point I want to set it up so I can have it easily changeable from hood to door frame to be ready for low trees and also water.
Congrats on the long travel!
Old 07-11-2012, 02:09 PM
  #39
Where did you get your fiberglass fenders from? I cant find them anywhere :p
Old 07-11-2012, 04:12 PM
  #40
Zpd426's Avatar
I got them from Hanneman fiberglass in Azusa CA, I think there might be one other company that makes them somewhere.
Quick Reply: 1996 t100 4x4 work in progress
