SWPERIC's 2002 4Runner Limited Build-Up Thread
Old 10-14-2009, 06:41 PM
SWPERIC's Avatar
Hello Yotatech. I love you. This website single-handedly enabled me to get back into one of my most rewarding hobbies. Modding automobiles.
Vehicle:
2002 4runner Limited
3.4 V-6 (5VZFE)
4 speed auto (A340F)
Mods:
Engine/drivetrain:
-AEM Brute Force Intake
-TRD cat-back exhaust
-Magna-flow cat
-Bypass OE transcooler with this part # 4454
-Flex-a-lite 210 Electric Fan Conversion
-4.88 differential gears set up by east coast gear supply
Suspension/Body Lift/Tires:
-Sonoran Steel 1.2
-1" Body Lift Kit from 4crawler
-Polyurethane Body Mount Bushings from 4crawler
-Yokahama Geolander AT-S 285/75/16s
-1 inch wheel spacers
Armor:
-Bud Built Skid and Belly Plate
-Stubbs Welding HD-Standard Sliders
-Sonoran Steel shackle hangers
Other:
-Tundra Brake Upgrade (231s)
-Painted wheels and grill to match
-Debaged
-Stereo Mods
-Matching Alloy Spare
-Black interior Carpet
I will try to write this in chronological order but its kind of all a blur. I am proud to say, i did every mod myself accept setting up my gears.
Aem Brute Force Intake - I know people poopoo these but I am careful at water crossings. The butt dyno did feel a noticable boost in torque. When I did it, I was towing alot and it helped.
TRD Cat-Back Exhaust - Sounds great. Not too loud. Again small Torque/HP Gains. I can't say that a custom exhaust would not have given the same results.
Had the TRD transcooler in line with the in-radiator transcooler but after reading about the strawberry milkshake, I bypassed OE transcooler with this part # 4454.
Then came the Sonoran Steel System 1.2 suspension lift and Yokahama Geolander AT-S 285/75/16s.
[IMG]http://i36.photobucket.com/albums/e21/EricJLindholm/dirtyrims1.jpg[IMG/]
I did need to run 1/4 wheel spacers with this set up to keep it from rubbing on the UCA. Then i had to trim about 1/4 in off the fender flare on the inside front of the front wheel wells. no rubbing after that.
Shortly after came the Budbuilt Skid and Belly Plate. There is no way to describe how tough this product is.
I then added a 1 inch 4crawler body lift. This is another high quality product. It makes things a million times easier to work on and run lines. there was no safe was to run my transcooler lines before the body lift. it gives my wheels a little more room to flex. see this post for a list of things made easier by a body lift. I also did polyurethane body mount bushings from 4crawler at this time. I would recommend this when doing a BL to help keep a solid feeling ride.
Here is a pic with the sliders welded on. The body lift allowed them to go on nice and high on the frame. These are the Stubbs Welding HD with no Kick out and the 15 degree bend. another great company to work with.
the only thing different from the pic above is i now have 1" wheel spacers. love em.
Ive got some more info to add about some maintenance things as well as check engine codes i have some experience with. as well as a few other little mods.
please feel free to comment on this. ill do my best to answer any questions not posted above.
Old 10-19-2009, 03:33 PM
SWPERIC's Avatar
just finished up changing the upper and lower ball joints on the passenger side as well as the axle tube seal and wheel speed sensor on that side. gotta stop to get ready to take the gf out for her birthday dinner. i hate taking her car but its prob not a good idea to drive with new BJs on one side.
it was alot easier then i thought it was going to be. from the posts ive read about it, i had it in m head that it was going to be near impossible. kinda like my first tattoo. had my self so freaked out that when i felt it i was like "o thats all it is?"
Old 01-28-2012, 08:13 PM
absalom's Avatar
sick rig man, did you paint your rims? if so, what color and how?
Old 02-02-2012, 02:14 PM
jason in tn's Avatar
very nice rig, really like the direction it seems your headed. I will be watching your progress.
Old 02-02-2012, 06:20 PM
alove0750's Avatar
Very clean ride!
Old 02-08-2012, 08:11 PM
Meltz's Avatar
Do you get any rubbing with the wheel spacers? I've got th same size tires with a 3in lift and was thinking about putting some of those on.
Old 04-13-2012, 04:57 PM
philster6's Avatar
what color on the rims and which products did you use to paint them?
Old 10-28-2012, 08:25 PM
kornhuskerwizard's Avatar
very nice mods. i like the stance an lift. you ever think about doing a gray wire mod?
Old 10-28-2012, 08:34 PM
i checked out the sonoran steel website. the 1.2 kit looks great. so its adjustable? you seem to be happy with it?
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
Road Bull
10-10-2015 04:55 PM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: SWPERIC's 2002 4Runner Limited Build-Up Thread
