Swimmerboy2112's 97' 4Runner
Old 04-04-2014, 05:51 AM
  #41
irab88's Avatar
Originally Posted by Swimmerboy2112
Transmission is in!
Went to plug in the manual trans ECU, no dice, the manual trans ECU has completely different plugs than the auto trans ECU. Oh well, guess I'll just have to live with a CEL, either that or swap wiring harnesses (kicking myself now for not grabbing the harness out of the 96' parts 4Runner).
yeah, but it makes my engine swap that much easier
Old 04-04-2014, 10:15 AM
  #42
Swimmerboy2112's Avatar
Originally Posted by habanero
Nice wheels!
Thank you!
That's one of the reasons why I didn't pull it, didn't wanna screw you over.
Old 04-04-2014, 10:58 AM
  #43
irab88's Avatar
haha, thanks bud
on either of the transmissions/engines, was there a cover plate for the bottom of the bellhousing? just curious, as i'm noticing a lot of 3vz and 5vz engines/trans don't have them, but they're referenced in parts diagrams.
also, i saw you took the whole brake/clutch pedal bracket. was there a stop switch attached to it?
Old 04-04-2014, 02:49 PM
  #44
haha, thanks bud
On BOTH the auto and manual there was a plate that covered the bottom of the bellhousing, it bolted directly on the bellhousing.
On the post-1995 stuff, the clutch pedal bracket and brake pedal bracket are separate. The clutch pedal bracket has a clutch depress switch and a clutch release switch. The brake pedal bracket has a stop switch which illuminates the brake lights once you push in the pedal.
Old 04-10-2014, 03:58 PM
  #45
All done
Old 05-05-2014, 06:40 PM
  #46
All done!
Old 05-06-2014, 03:19 AM
  #47
habanero's Avatar
All done!
Unpossible!
(looks good)
Old 05-06-2014, 03:27 AM
  #48
Unpossible!
(looks good)
Well I should have said, the lift is done!
And thanks!!
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: Swimmerboy2112's 97' 4Runner
