Porkys4runner's 1997 4Runner Build-Up Thread
Old 07-20-2010, 06:57 AM
Porkys4runner's Avatar
Thanks! The font is because i type this on micro. word and paste, since its usually an essay, helps me catch errors. lol
Old 07-20-2010, 07:03 AM
Fink's Avatar
Smart!
You should use Firefox - has spell check built in!
Fink
Old 07-20-2010, 10:06 AM
Mauzer's Avatar
Nice score on the bumper and glad ya got it started. As far as the hardware I think it may just be the bumper bolts, I work on my runner all the time w/o incident but this weekend I took my front bumper off to modify it for the 1.5" BL I installed the prior weekend and was snapping bolts off! Especially those dang wheel well bolts, anyway, rant off...keep up the good work
Old 07-20-2010, 12:01 PM
Yeah, im worried, the rear end looks very crusty in this thing. Im getting worried how long this vehicle will actually last me due to the thin metal on it. My truck is a 94 and the body is rotted right out but the frame is still looks nice. I like it and really want to keep it but if its going to give me major problems id rather just sell it for what I got into it. I love it but I need stuff that lasts the longest against salt, we get it so bad here, depressing….. I love snow, but hate salt…..
Old 07-21-2010, 04:12 AM
  #25
Pics of the jerry rigged radiator support.
Attached Thumbnails Porkys4runner's 1997 4Runner Build-Up Thread-img_1077.jpg   Porkys4runner's 1997 4Runner Build-Up Thread-img_1078.jpg   Porkys4runner's 1997 4Runner Build-Up Thread-img_1079.jpg
Old 07-21-2010, 04:13 AM
  #26
Quick cluster shot.
Attached Thumbnails Porkys4runner's 1997 4Runner Build-Up Thread-img_1080.jpg
Old 07-21-2010, 04:21 AM
  #27
bigt's Avatar
man i hit 2 deers going 60.. besides some cosmetic damage there was no issues.. toyota can take it...
does it have the rr rear diff?
Old 07-21-2010, 05:12 AM
  #28
Im guessing you mean the lockable rear diff? I read a little about it and know its more on the rare side. If so, i dont think it does. There is no switch to the left of the steering column besides the dimmer. I wish it did... The deer was a buck, so it was big, real big, they showed me pics.
Old 07-21-2010, 11:47 AM
  #29
Also to put this out there i am looking for at least 2 more Tacoma/Tundra/Sequoia Rims that match my two front rims so i can have a full set instead of two pairs. I am not a fan of the 3 spokers. I have a set of 265 wrangler T/D's off my Silverado that would be nice trail tires. I responded to two ads on craigslist, but they were old....
Old 07-22-2010, 03:29 AM
  #30
Got it out and drove it around the yard.
Attached Thumbnails Porkys4runner's 1997 4Runner Build-Up Thread-img_1084.jpg   Porkys4runner's 1997 4Runner Build-Up Thread-img_1085.jpg   Porkys4runner's 1997 4Runner Build-Up Thread-img_1086.jpg
Old 07-22-2010, 03:30 AM
  #31
Back shot.
Attached Thumbnails Porkys4runner's 1997 4Runner Build-Up Thread-img_1087.jpg
Old 07-22-2010, 03:33 AM
  #32
So got it fired up and drives well. The radio and interior lights now work. But the power antenna doesn’t go up. I think I am going to look into the Tacoma whip mod to make it nice and simple, I don’t go through car washes anyway. The clock also does not work. It does have a brake line leak, the front of the brake reservoir was empty and started leaking as I drove it. Its right under the drivers side rear door. Fixed the battery drain also.
Old 07-23-2010, 04:37 AM
  #33
Ok,
Next step. Got the passenger side fender off. Snapped all the bolts that hold it on down low, so now it’s a sloppy fit. This bolt snapping thing is getting old real fast…. And of course I cant get a drill in there because of the factory running boards. The door still hits the fender with it popped out, so I am going to have to adjust it a little so you can open the door and it doesn’t come back to bite you.
Attached Thumbnails Porkys4runner's 1997 4Runner Build-Up Thread-img_1091.jpg   Porkys4runner's 1997 4Runner Build-Up Thread-img_1092.jpg   Porkys4runner's 1997 4Runner Build-Up Thread-img_1093.jpg
Old 07-23-2010, 04:38 AM
  #34
Little body work...
Attached Thumbnails Porkys4runner's 1997 4Runner Build-Up Thread-img_1094.jpg   Porkys4runner's 1997 4Runner Build-Up Thread-img_1095.jpg   Porkys4runner's 1997 4Runner Build-Up Thread-img_1096.jpg
Old 07-26-2010, 04:31 AM
  #35
Got a bit further on the 4runner last weekend. Started a new high idle thread in the tech section after cleaning the throttle body out. The throttle had some carbon and sludge buildup that must have hardened over the 6 years of sitting. Ran into an issue in removing the IAC, that’s so dumb that they used Phillips screws, nice and easy to round off. I got two out with an impact and stripped the others. Luckily got them out with vise grip needle nose pliers. I am going to the hardware store today to get some hex head cap screws to replace the Phillips. The IAC was a little gunked up too inside. So I will also get some more brake kleen today so I can clean that part out. I will put it back together and try it again tonight. I bought the gasket at a local advance auto for 2 bucks. Hopefully its good and just needs a cleaning. I also replaced the CTS, but that didn’t help. Also got the front radiator core support on, the drivers side fender is a little bent so it doesn’t quite line up, for now it will have to work. So, I am down to needing: fan shroud, parking lights, turn signal lights, bumper, brake line, tires mounted and balanced and the idle issue figured out. OH, and most importantly a title still……… Pictures to come later, forgot my camera at home today....
Old 07-27-2010, 03:52 AM
  #36
Got the high idle fixed! Needed a good IAC cleaning. Now i need to fix the brake line, get a bumper, and figure out a rim choice. Forgot the camera once again.... Bought a lh [parking light on the bay for 5.00 bucks last night plus 5.50 s&h. IM going to make the rh light work with a broken pin for now.
Old 07-27-2010, 08:09 AM
  #37
Got looking into spacers so i can fit the tacoma rims and 265-75-R16's. I think im going with wabfabs 1''. I dont like the washer spacer method, it scares me, but i wonder if 1'' is too much? Does anyone have pics on a stock runner? If it looks good and doesnt stick out to far i would be so happy. Thanks!
Old 07-27-2010, 08:47 AM
  #38
Fink's Avatar
1" spacers would be huge dude - I would try bolting them up first and see how much space you will actually need.
Fink
Old 07-27-2010, 09:39 AM
  #39
Yeah, i was worried about that. I need to find the backspacing out on the stock runner rims and tacoma rims.. Even the runner rims with 265-75R16's have to be close to the a-arm...
Old 07-28-2010, 03:25 AM
  #40
Front end coming together., new IAC bolts (stupid phillips stripped out...
Attached Thumbnails Porkys4runner's 1997 4Runner Build-Up Thread-img_1111.jpg   Porkys4runner's 1997 4Runner Build-Up Thread-img_1112.jpg   Porkys4runner's 1997 4Runner Build-Up Thread-img_1113.jpg
Quick Reply: Porkys4runner's 1997 4Runner Build-Up Thread
