MKtaco_98's 1998 Tacoma Build-Up Thread
#321
Lazy? I workout five days a week after work for two hours, I have been painting my bathroom and I am anal when it comes to painting; also, I have been working through the garage to make the space more then usable. Lazy?
The following users liked this post:
Mk_98 (03-18-2021)
#324
The engine did not blow, it still runs great; just with what sounds like rod knock. Speaking of rod knock, I did think recently that the sound could also be related to a piston taping a valve, which would be awesome if that is the case.
#326
It's pretty easy to work on the 22re. I have a non-ac single cab now and i can grab both motor mounts with my hands. Even the bellhousing bolts are visible under the hood
#327
High compression piston could contact and if the contact is light there would only be marks on the piston face. compression is spot on and I have not pulled the filter or done any work to since I parked it. Either way the engine must come apart. I is a nice thought if it is not a bearing
#330
not necessarily, keith. if the contact from valve to piston is light enough and no damage has been done, you could probably do what i did and get a thick cometic MLS head gasket and ARP studs. you wouldnt need to tear into the guts of the motor then. id get a borescope and check it out, because that something we could knock out in a day in your driveway, not the garage.
#332
@Mk_98 , wheres the new build thread with the pics?
MaK92-4RnR (03-19-2021)
scuba
798
02-26-2017 03:46 PM
CodyX36
151
06-23-2015 05:33 PM
1980 4x4
12-15-2012 01:36 PM
ADH8796
08-05-2007 07:40 PM
