cody91 1997 4Runner Build-Up Thread
Old 12-06-2013, 11:42 AM
Cody91's Avatar
Exclamation cody91 1997 4Runner Build-Up Thread
Hey every one!
This is a Build-Up Thread for my 1997 4Runner
  • 3.4 V6
  • 5 Speed
  • 218K
  • 4x4
  • Stock
  • PC Black 16 stock Rims
A few things i found out about on the 1st night
  • No rear Wiper blade arm or wiper
  • key Does not Work in the Lift gate
  • no Back up Lights
  • 4X4 Dash Light Does not Light up when in 4Low or 4High
  • Sound system sucked ....
The plans !!!!
This is not a crazy rock crawler! its a trail Truck & DD
(DONE )
( Still to do )
(On the Way)
Lift
Front:
Icon Coil-overs (Done : at 2189xx mi)
Sway bar bushings (Ordered 2/14/14)
3/4" or 1" Diff drop
Lower Ball joints
MOD : Steering Stop weld
Re-Build CV joints (new boots)
Lift Rear:
OME HD Coils (Install 02/14/14)
ICON Piggyback Shocks p#57700 ( ordered 02/12/14 2 week build time)
Sonoran Steel Adjustable Trac/PanHard Bar
Sonoran Steel Extended Bump Stop Adapters
Daystar "Competition Style" Bump Stops
Rear Sway Bar Adjustment Brackets
Braided Stainless Steel Extended Brake Line-
Parking/Emergency Brake Bracket
SOUND
Keenwood Deck
keenwood 1000w Amp
Fosgate P3 12"
Ported Box
Random Stuff
Roof rack
255/85/r16 KM'2s
power coated Stock Rims
trim removed
Bumper Bed lining coated
More to come in the list of things to do !
I know i know Pic Time !!!
The Next Day
Old 12-06-2013, 11:51 AM
Cody91's Avatar
New Shoes
Well the Tires were not cutting it for me and they were old and hard..
So i Got her some new Shoes
255-85r16 BFG K/a 2 ( Done 217.9xx)
( Yes They Do Rub on full Lock and on the Pinch Weld. All stock )
Old 12-06-2013, 12:03 PM
Cody91's Avatar
Roof Rack
Bored so i got a Roof Rack
and got under the Runner and found some stuff
  • back up Light Switch is Busted at the Tranny plug
  • Sway Bar Bushing are dead F&R
  • Transfer case has a leek (Fluid is good as of 11/23/13) Check in a few days
  • rear end is fresh Fluid
  • need to Lube all joints
found a Stock 97 Runner Limited with leather Bone Stock to Show off the tires
Tires make her look good
Old 12-20-2013, 11:55 AM
Cody91's Avatar
Smile Update ! New parts !
Update !
218,200 miles Got a CEL " Miss Fire on #5 "
Bad idle and was only running on 5 not 6
Replaced Plugs cleared the CEL and it is now gone and runs good!
218,6xx
Replaced the stock front coil-overs with some DR/ICON coil-overs
Before
Left side 19.1/2 "
right Side 19. 3/4"
After
Left front 22.1/4
Right front 22.1/2
Before Tires
After Tires
After Tires and coil-overs
Old 12-28-2013, 08:55 PM
Cody91's Avatar
bumper Mod
Bored and had a idea for my stock bumper till i can replace it
So i got some
Primer
Spray on bed liner in a spry can
buff pad
sand paper
Taped it off took the turn lights out and ruffed it up and cleaned it and did primer and two layers of bed liner
Old 02-13-2014, 06:38 PM
Cody91's Avatar
Smile Small update and New parts !
So Coils came in the mail to day!
Going to install this weekend. I have to get some cheap lift shocks wile i wait for my ICONS 2.5 Piggyback's get here!
Also Painted the Toyota Logo Factory color.
Old 02-14-2014, 04:36 PM
FJHammerHead's Avatar
Like the black bumper front, now you just have to do the rear....
Old 03-24-2014, 03:12 PM
Everest's Avatar
How is the rattle can bedliner on the bumper holding up? Looks great so far.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
jon.r
07-11-2015 03:34 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: cody91 1997 4Runner Build-Up Thread
