1998 4Runner sputtering
Old 02-06-2013, 03:47 PM
TangoDown's Avatar
I just had a tune up on my 98 4runner 3.4L 2wd and replaced a coil but it's still sputtering and misfiring. Any suggestions? Thanks
Old 02-06-2013, 05:57 PM
stockwell45's Avatar
Any CEL?
Old 02-06-2013, 06:04 PM
TangoDown's Avatar
The CEL had been on for an O2 sensor but it hasn't had a CEL since the tune up yesterday. It is sputtering intermittently.
Old 02-11-2013, 01:34 PM
mastacox's Avatar
Sounds like you'd better try replacing your o2 sensor, it could be your engine is running either too rich or too lean due to a sensor issue.
Old 03-22-2013, 11:45 PM
griffin1ets's Avatar
Was it o2?
Old 06-19-2013, 06:27 PM
fhalperformance's Avatar
I would start with the oxygen sensor. Are you using the oem type spark plugs? I have a similar issue on my build. It ran alot better after I put the right spark plugs in. Could be coil, spark plug type, spark plug wire make, injector, engine ground, head gasket issue.
Flying91
45
04-11-2024 04:39 PM
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
the1998sr5
15
07-14-2020 08:35 PM
BeMiceElf
10-10-2015 09:40 PM
Quick Reply: 1998 4Runner sputtering
