Will denso O2 sensor for manual fit an automatic?
Old 02-26-2013, 10:40 AM
Col Klink's Avatar
Hey,
I ordered the wrong denso O2 sensor (234-4161). Apperantly this sensor is for a manual and my truck is a automatic. Does anybody know if they are interchangeable.... the only obvious difference to me is the wiring harness is longer. Your thoughts
Old 02-26-2013, 10:23 PM
TheDurk's Avatar
Originally Posted by Col Klink
Hey,
Denso's flange mount o2 sensors for the 3rd gen 1996-1998 (as opposed to A/F sensors, which are totally different) are all the same except for the wire length. The proof of this is that the 234-4206 universal sensor (that has no harness plug, just a pigtail) can be used in all applications up through 1998, including those calling for the 234-4161. In 1999, you start having A/F sensors on the Cali. trucks and then you run into screw mount rear sensors in even later trucks, so you have to be a little more careful.
Old 02-27-2013, 05:48 AM
Col Klink's Avatar
Sorry.... i should've mentioned it is non-Cali truck. 1999 4runner sr5, 3.4 Lt. automatic.
So..... the Sensor (234-4161) I ordered is for a 1999 V6 non-Cali., manual tranny. Can this sensor be used on a automatic? Anybody?
Old 02-27-2013, 06:06 PM
1blink's Avatar
Hey,
My research indicates no. Wish I saw this 3 days ago. I bought the wrong one as well, we could have swapped. Oh well.
See the following link for part#s
http://www.urdusa.com/index.php?cPath=9_13
Old 02-27-2013, 07:04 PM
TheDurk's Avatar
I got that. If the wire reaches, it will work fine. I just put the other info in for other people with other trucks who might read this.
Old 02-27-2013, 07:12 PM
TheDurk's Avatar
Please share your research, because I disagree. If the wire reaches, it will work. And if it doesn't, you can cut the old plug and wires off and solder it to the new sensor to get more wire length (after you cut off the new plug.)
Old 02-28-2013, 06:46 AM
Col Klink's Avatar
good deal..... thanks Durk. I will confirm if it they are indeed interchangeable this weekend.
Old 02-28-2013, 07:01 AM
1blink's Avatar
My research was simply looking up part numbers. They may function ok. I would compare before/after gas mileage closely.
Old 02-28-2013, 07:20 AM
Greg_Canada's Avatar
Yes, they are the same sensor with different wire lengths.
Old 02-28-2013, 08:53 AM
TheDurk's Avatar
The sensors themselves are identical. No comparing required.
jb451
7
10-07-2022 06:58 AM
Longbed 90
03-11-2019 12:38 PM
Longbed 90
10-19-2015 11:05 AM
larrys93pickup
09-17-2015 07:05 PM
krimsonone
07-29-2015 11:53 AM
Quick Reply: Will denso O2 sensor for manual fit an automatic?
