Wideband Help
Old 07-14-2013, 06:29 PM
Swimmerboy2112's Avatar
Wideband Help
To all of you first gen Taco owners, how did you install your wideband?
The bung in the exhaust is made for this kind of 02 sensor.
And the wideband sensor is a screw in style like this.
Old 07-14-2013, 06:38 PM
totally a bro
Staff
vital22re's Avatar
buy a weld in bung.
cut hole,weld in bung.
install wideband.
Old 07-14-2013, 07:11 PM
Originally Posted by vital22re
buy a weld in bung.
install wideband.
Yeah thats the route I didnt wanna go. Does no one make a bolt-on wideband sensor?
Old 07-14-2013, 08:37 PM
gigatech88's Avatar
Not that I know of. I also didn't Search at all. You could UN wire the wideband sensor. Or unplug if it's not hardwired to the gauge.take some flat steel/ whatever you have and make a piece the same size as the mounting of you're original O2 Sensor. Drill your holes for bolts , skip the wires through and Mount it. Assuming the screw In type is the same diameter of the hole and sits flush.
It's not the ideal way to do it.But if you don't want to weld , it will work. I've done it on a couple different vehicles as the customer didn't want to spend the cash for removal of the old O2 sensor hole. If you've got all the supplies to make it work is free.
If I make no sense I can get you an image.
Old 07-14-2013, 08:58 PM
totally a bro
Staff
vital22re's Avatar
an exhaust shop will either install it for you super cheap or free depending who's working that day.
Old 07-14-2013, 09:04 PM
gigatech88's Avatar
Valid point. I have a habit of fabricating things myself. I'd go vitals route. It wouldn't cost much at all.
Old 07-15-2013, 12:25 AM
wyoming9's Avatar
Red face
Really sucks when you can`t weld or don`t have the access to the equipment.
one thought find a piece of pipe big enough to slide over your exhaust .
go over the front and into the back side of the exhaust most auto parts places have or can get one.Have one made by any one with a pipe bender
have the sensor bung welded in remove enough original exhaust slide new piece on 2 clams done
I have seen clamp on bungs but most tend to leak. If they are not installed just right.
Old 07-15-2013, 03:31 AM
What you said makes sense, I was thinking the same thing, or thinking about tapping the hole and threading it in.
Yeah that's true, just getting it down there would be an issue as i'd have a hole in my exhaust hah
Well I would just do that but I'd like to use this 02 bung that is already there, but if I have to cover it up and weld a new bung in, so be it.
Well here's the thing, I do have a welder and I know how to weld, that is not an issue. Basically I was trying to utilize the 02 bung that was already in my exhaust.
Old 07-15-2013, 10:26 AM
wyoming9's Avatar
Red face
Can you not get the sensor with the Toyota style flange.
If you put the sensor threaded into a bung welded to a piece of flat bolted to the pipe would the sensor be to far out of the flow to read correct.
In essence you would be making a flange to bolt to the Toyota style mount.
You should know some one who has a tap that size the correct drill bit.
That way you maybe could use your existing location.
Old 07-15-2013, 07:35 PM
As far as I know you can't get it in that style.
I think I will try and tap and make a flange.
Old 07-16-2013, 10:52 AM
se7enine's Avatar
Found this using google http://www.mandrelbendingsolutions.c...-Flange/Detail
may not be good for the Wideband because it will sit too low in the pipe and should sit flush with wall of exhaust.
cpljenkins01
02-25-2015 08:54 PM
skrassow
10
02-23-2013 11:00 PM
Robb235
02-17-2013 03:18 PM
bone collector
02-17-2013 12:57 PM
Shogun1011
08-13-2007 07:07 AM
Quick Reply: Wideband Help
