Where's the heat sending unit?
Old 06-29-2004, 01:03 PM
creepingdeath's Avatar
Question Where's the heat sending unit?
The temp guage in my 84 4runner has did weird crap the whole time I've had it (goes half way up right after it's started, reads normal then drops all the way down to cold, etc.}. I'm fixing to do a whole lot of driving in the desert, and I want an accurate reading of my engine's temperature. I think the guage is alright, but I'm not sure where the sending unit is. My truck came with a 22R, but I think it might actually have a 22RE fitted with a carb if that makes a difference in where the sending unit is. If anyone has some pictures they could post of the sending unit, or if something else might be making the guage read screwed up it would be appreciated.
Old 06-29-2004, 08:30 PM
Duffdog's Avatar
hmmm...its on the top near the efi unit in the block on the 22re--- cant imagine it would be moved on the 22r-- might have to take the carb off, but it should be on the block somewhere in the water jacket.
T
Old 06-29-2004, 09:44 PM
superjoe83's Avatar
thats weird, mine does the same thing, also my oil pressure gauge doesn't work, anyway i thought that it may be a sending unit going bad, so i un-hooked all of the connectors on the intake and the gauge still read normal when it should have gone to cold, i also grounded the oil pressure wire at the sending unit and all i got was a twitch of the needle, i think that the gauge cluster may be at fault, i wish that i knew someone with an 84 SR5 so i could try their cluster, oh well, i guess that i will have to buy aftermarket ones :pat:
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
Obmi
10-04-2015 11:30 AM
Matthew Perez
09-28-2015 05:43 PM
87runner_
09-09-2015 09:51 AM
Quick Reply: Where's the heat sending unit?
