Where to find oversized altenator
Old 04-01-2005, 10:44 AM
Bigkahuna808's Avatar
will that alternator fit the 3.4l 5vfe engines?
Old 04-01-2005, 02:58 PM
node's Avatar
Yea, I have the MR2 alternator on my 3.4L 5VZ motor.
I would like to do a write up explaining what connector you need and take some pics but its soooooo tight in my engine bay that its difficult to get good pics. Im about 90% certain that you need the MR2/camry/celica/solara/carolla alternator plug probably like $5 for the plug and some decent legth wire at a yard. I remember that the the 4runner plug looked different but I was upsidedown under the car when I was pulling that section of the wire harness out. Again $5 is still way cheaper than a custom alternator. Ill get some pics if I can ge the camera in there next week when I have some time between classes and work.
Old 04-02-2005, 05:37 PM
getitdone's Avatar
Originally Posted by jimabena74
I did this swap, easy and affordable power. I can dig it.
Old 04-03-2005, 01:05 PM
cool cant wait for the pics
Old 04-06-2005, 04:56 PM
  #25
leebee's Avatar
h/o alternator
hey chris!
if you ever get over kitchener way, there is a place called highland starter and alternator that i have been talkikng with in this regard. they can get me a 150 amp unit and install it for around 250$ less core charge. might be worth a trip west now that the nice weather is here.
lee
Originally Posted by Yota4runner
Yeah, my Baja Desert foxes, and even my Hellas tend to put a small strain on my alt. Its stock. I'm gonna go with a Bigger one and a better battery evetually.
Old 06-11-2005, 05:33 PM
  #26
Albin's Avatar
Chris, how did it go?
Thanks,
Al
Old 09-09-2005, 07:33 PM
  #27
Ironmike4x4's Avatar
Bump.... Maybe a write up finally with some pics?
Old 09-10-2005, 08:33 PM
  #28
getitdone's Avatar
It went pretty smooth. It was like a year ago or something and I have had no problems with the alternator. Great swap IMO!
Old 04-16-2012, 09:00 PM
  #29
Oldscooltoys's Avatar
What gm alternator do you look for? What pickup or anything ?
Old 04-16-2012, 11:17 PM
  #30
dewiseman's Avatar
Have you upgraded your wires? Larger cables and larger wire to the fusebox? If your not running a winch then bigger / new wires might be all you need. Corrosion in older wires can really make a difference.
Old 04-16-2012, 11:25 PM
  #31
Corrosion even a little corrosion can cause it to draw juice or not charge the battery?? Meanin I have a alt wire that's jus a little corroded ( somewhat blue) and that's it
Old 04-16-2012, 11:49 PM
  #32
dewiseman's Avatar
Think about it this way. All the times you've cleaned the corrosion off, you have only cleaned the end of the cables. The corrosion runs through the entire length of the cable but that corrosion has never been cleaned out. Also take a look at the wire that runs from the alt to the fuse box, that stock wire is tiny and yet it is expected to carry the juice to run all your fused accessories. Unless you are running your lights straight from the battery then that wire needs to be upgraded IMO.
Old 04-17-2012, 12:02 AM
  #33
Ok I'll try and replace som of that and if my voltage meter keeps goin bak and forth I'll get bak here tomarow thanks for the help dewiseman for the tip get bak about that tomarow
Old 04-17-2012, 12:31 AM
  #34
One more thing if you could help me figure this out I'm wanting to out in a gm alt I've seen threads of it n I want to put one in my 94 4runner to run a sound system n possibly add another battery later but do u kno what type of alternator I should get from mayb a junk yard? What vehicle I could pull it from?
polo451
13
11-20-2016 07:49 PM
rondogracing
Engine Swaps
16
08-24-2015 03:02 AM
HookahRoo
07-20-2015 07:06 PM
scottyg486
07-19-2015 05:34 PM
sojourner567
07-16-2015 08:52 PM
Quick Reply: Where to find oversized altenator
