where is the engine to chassis ground? 2002 tacoma truck?
Old 06-23-2010, 08:22 PM
Billinsd's Avatar
Where is the engine to chassis ground on my 2002 tacoma truck? I found the neg battery terminal to engine ground easily.
Thanks
Bill
Old 06-23-2010, 08:28 PM
Fossilized
Staff
dropzone's Avatar
check around the motor mounts
Old 06-24-2010, 05:09 AM
Billinsd's Avatar
Thanks, I'll take a look
Bill
Old 06-24-2010, 06:08 AM
mt_goat's Avatar
Look around under the oil filter.
Old 12-11-2014, 10:14 PM
86bedlesstoy's Avatar
Whatever came of this? Bill what was your reasoning?
Old 12-12-2014, 07:50 AM
Junkyard Dog's Avatar
As Mt Goat and Dropzone said, there is a ground close to the oil filter pad that goes to the frame, and at least on my truck (5VZ) there is another at the passenger rear cylinder head going to the firewall near the heater control valve. HTH.
Old 12-12-2014, 01:21 PM
wyoming9's Avatar
Red face
I have one goes to the engine block.
Another goes to the frame
One goes to one of the inner fender bolts
The one for the ECM goes direct to the battery.
Old 12-13-2014, 02:29 PM
ThorInc's Avatar
Can a strut bolt work as a substitute?
Old 12-14-2014, 01:40 AM
wyoming9's Avatar
Red face
Yes for a frame ground but you still want one to the engine block.
Because the starter grounds through the bolts via the block
duckhead
170
11-13-2017 06:07 AM
vasinvictor
01-20-2016 12:39 PM
merc1100sc
06-26-2015 05:24 PM
dirtrider0129
10
06-24-2015 12:24 PM
Quick Reply: where is the engine to chassis ground? 2002 tacoma truck?
