what tranny came on a 97 taco 4wd 2.7 (5spd)?
Old 04-15-2009, 05:08 PM
tommthebomb's Avatar
I have a buddy who has a 2.7 motor and trans. w/ transfer case, that came out of a 1997 Tacoma 4wd. It had an engine fire, and that appears to be garbage, but I was wanting to see if the tranny would work for my 86 22re auto to manual swap. I have heard it may be a R151F, but wondering if that would be too good to be true? As the 151F bolts right up to the 22re, correct? An R150F setup would do me no good, unless I could find a correct bell housing from a turbo or 151F? Correct? Thanks, sorry for any confusion, I am just trying to get this straight. Thank you all!
Old 04-15-2009, 07:05 PM
3w41d's Avatar
i know that the 3RZ-FE uses the W59 transmission
not sure about the swap
Old 04-15-2009, 07:42 PM
crolison's Avatar
its a w59, your looking for trouble with swapping that trans into your 86.
You would need a w56 bell housing, then another adapter to run a passenger drop tcase.
Just save yourself some money and time and find a whole w56 setup.
Old 03-04-2014, 03:43 PM
Srtautoworkz's Avatar
Hi I'm new to the forum trying to figure out if the 2.7 Tacoma transmission is the same as a pre-Tacoma from 85 to 95??? I'm trying to put a pre-Tacoma transmission and a Tacoma 96 thanks Steve srtautoworkz ct
mskalmus
05-28-2017 07:51 AM
yipyip45
08-06-2015 02:05 PM
ripp96
07-31-2015 11:14 AM
mr_manny
07-31-2015 10:39 AM
ripp96
07-25-2015 02:32 PM
Quick Reply: what tranny came on a 97 taco 4wd 2.7 (5spd)?
