What does the computer do on a carbureted truck?
Old 10-15-2004, 04:12 PM
the_supernerd's Avatar
I am wondering what the emissions computer controls on a carbureted 22R. I see some sensors, but I cannot seem to figure out what it controls. Does anyone know what it does? Does it store codes that can be retrieved?
Old 10-15-2004, 08:59 PM
toy283's Avatar
It is a very rudimenary form of emissions control found only on California spec trucks. There should be a couple wires going to the carb (on top of the bowl) and an O2 sensor and maybe a temp sensor depending on year. The wires going to the carb control a solenoid-operated metering rod which richens/leans out the mixture as told to do so by the ECU and O2 sensor. My experiences with this system have told me it is somewhat trouble-prone and the metering rod tends to be stuck in one position, usually somewhere in the middle of the range (where it spends most of its time), and doesn't really have any detrimental effects to performance and/or emissions. I'm not positive, but I don't believe this system stores any codes as there really aren't any to store, it just doesn't monitor enough equipment.
Old 10-16-2004, 10:54 AM
Thanks for the reply. I have a lot of carbon build up and I was thinking that maybe my mixture is rich, so I will check that.
Old 10-16-2004, 11:52 AM
kyle_22r's Avatar
i though all trucks from the mid 70s on to the end of the carbureted era had a little "computer" box in them. my friend's 76 did, my '79 does(albeit unplugged ), and my '84 2wd had one. all were federal emissions trucks, and the box said "emissions" computer on them
from what i've heard, they do a few basic functions, and also control the fuel cut solenoid which helps prevent raw fuel washing down the cylinder walls and improves engine braking
Old 10-16-2004, 12:26 PM
stevrock's Avatar
I'm pretty sure it moniters cooling fans and the heater and all the little electrical components also.
Old 10-16-2004, 03:22 PM
kyle_22r's Avatar
not on a carbed truck, i don't even think EFI trucks had any kind of fan monitor
Old 10-16-2004, 03:27 PM
toy283's Avatar
My '84 had no computer whatsoever. No O2 sensor, no other sensors (other than gage and idiot light), no wiring other that required for engine operation, etc.
Old 10-16-2004, 04:21 PM
jimbo74's Avatar
i have an 85 4x2 22r CA based truck... i have a "emissions computer" under the right kick panel
Old 10-17-2004, 11:32 AM
aviator's Avatar
Canadian trucks had one of these also :-)
duckhead
170
11-13-2017 06:07 AM
Jdgarrison
10-01-2015 05:22 PM
MadMax48
07-03-2015 08:26 AM
paxanders
06-21-2015 06:29 AM
Quick Reply: What does the computer do on a carbureted truck?
