Which way do these wires go back in on the fuel pump?
Old 09-04-2010, 08:22 AM
dallison's Avatar
I had to drop the fuel tank and i didn't discconnect the harness for the fuel pump.
These wires came out of their socket and i don't know the proper order.
2001 sr5 sport
Old 09-04-2010, 08:28 AM
clydehatchet's Avatar
this should have all you need http://www.ncttora.com/fsm/
Old 09-04-2010, 06:32 PM
dallison's Avatar
thanks, i found the plug on there, but still have to find the correct wiring diagram.
Old 09-04-2010, 07:12 PM
wyoming9's Avatar
Red face
You are so not going to live this one down!!!
Why pray tell did you need to remove the gas tank ??????
I am thinking that two wires will be for the fuel pump the others for the sending unit you can tell here she doesn`t need a gas gauge.
Old 09-05-2010, 02:57 AM
dallison's Avatar
lol, the e-brake cable was secured above the fuel tank and i couldn't remove the bolt so all that ˟˟˟˟ had to come down for easier accesss........
Old 09-05-2010, 03:27 AM
dallison's Avatar
surprisingly after reading the wiring diagram twice i can't get a definitive answer which way is correct.
The plug is f10, the only wires it shows are the blue and the white ones. It doesn't show position or the other three wires. I am prob not reading it correctly.
Old 09-05-2010, 06:58 AM
wyoming9's Avatar
Red face
Look at the sending unit it will no doubt have the other three and the colors .
If you look at the other side of the plug the colors should be the same just match the pins to the correct color.
If you need help call you know my name I am in New Tripoli I am in the phone book.
Old 09-05-2010, 07:24 AM
dallison's Avatar
i thought of that, but the thought of having to drop the tank again made me shudder.....
If i need to i'll do it at some point.
Old 09-05-2010, 08:26 AM
TheDurk's Avatar
It's in there--it's just in two different places. The fuel sender F10 is under Combination Meter: 1-Orange 2 Yellow-Red 3- Brown-Black.
The Fuel Pump F10 is under Engine Control: 4 - Lavender Orange 5- White-Black.
Yeah, I know. 4 doesn't match. So it has to be 4 = Blue. Your year must be different than the one posted on-line. Boy, you posted this all over the Internet. Glad I could help.
Old 09-05-2010, 12:36 PM
wyoming9's Avatar
Red face
I thank you know telling when Mr dalision might look at the thread
That is what I meant look in the print for the sending unit not on the tank.
Old 09-05-2010, 01:33 PM
dallison's Avatar
woohoo! thanks durk for the wiring and wyoming for support. The truck runs and all seems normal, except the abs, trac off vsc off lights are on. I need top find out what was else was disconnected or stretched.
I have the ebrake cable off so i wonder if that has anything to do with it.
Old 09-05-2010, 01:59 PM
TheDurk's Avatar
Glad it worked.. That light trifecta is common, I know. My '99 doesn't have that stuff (except ABS). Off the top of my head, I would check the ABS sensor on top of the diff--it's right where the e-brake cable goes by; pretty sure that's a possible if it is unplugged or damaged.
Wyoming 9--My brother has a dairy farm in Kempton, PA less than 10 miles from New Tripoli. I am out there a lot. Beautiful area.
Old 09-05-2010, 10:16 PM
wyoming9's Avatar
Red face
Durk next time your up this way your welcome to stop for a visit. Just let me know
Sure not many dairy farms left. I sure would not wish that on anybody these days with the price of fuel. Since most people think milk comes out of a carton.
Well I am glad your wife`s 4Runner is running except for the emergency brake meaning no rear brake adjustment
Old 09-06-2010, 06:44 AM
dallison's Avatar
lights are off. The center console broke a wire on the abs unit.
Old 09-06-2010, 09:50 AM
TheDurk's Avatar
Thanks! Any nice 4x4 roads out that way that are public access? I have not explored much as there is usually a lot to do at the farm. Bro likes to take advantage of my mechanical skill.
stagger_lee
03-29-2016 06:27 PM
puffin04
07-10-2015 09:17 PM
OffroadRalph
07-02-2015 07:28 PM
rbravo1
06-29-2015 01:34 PM
Dennis140
06-17-2015 10:37 AM
Quick Reply: Which way do these wires go back in on the fuel pump?
