VSC, CEL warning light reset
Old 11-17-2012, 10:26 AM
bobs02's Avatar
I'm going to replace the air fuel sensor in a friend's 02 4runner today. Will the VSC and CEL warning lights go off afterward or is there something I need to do to reset them?
Old 11-17-2012, 01:11 PM
j2the-e's Avatar
On most older models, remove the efi fuse and the light will turn off. Not sure if it works on an '02. If that doesn't work, you may need a scanner. If the problem is fixed, the light will turn off on its own eventually, usually after the monitor runs and passes twice.
Old 11-17-2012, 02:57 PM
brianh699's Avatar
Removing efi fuse will work, for check engine light. VSC is probably a different circuit, you can disconnect the battery and reset both.
Old 11-17-2012, 03:34 PM
MudHippy's Avatar
Correction...thrice(3x).
From the FSM...
If the malfunction does not reoccur in 3 trips, the MIL goes off but the DTCs remain recorded in the ECM memory.
MIL = Malfunction Indicator Lamp(just another name for the CEL)
Old 11-18-2012, 08:14 AM
bobs02's Avatar
Thanks for your help with this.
AkitaDog
09-01-2015 08:05 AM
256mbaker
07-31-2015 06:45 PM
nonstop
07-24-2015 06:29 PM
Odin
07-15-2015 09:28 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: VSC, CEL warning light reset
