Valve cover gasket question
Old 11-01-2013, 09:38 AM
98 Black SR5's Avatar
I changed them and only used the gasket when reassembling. I didn't use RTV anywhere. Was I supposed to use it on the halfmoons or in the corners?
Old 11-01-2013, 10:00 AM
rworegon's Avatar
Both. On the seam of the half moon and in the corners per the FSM.
Old 11-01-2013, 03:20 PM
Ok thanks. Luckily I haven't set the intake back down yet so can get to them. Do I apply it on top of the gasket or on bottom?
Old 11-02-2013, 05:28 AM
rworegon's Avatar
The RTV/FIGP gets applied directly to the cleaned head surface. There are threads around here that show a picture of the exact locations.
Old 11-02-2013, 06:56 AM
Thnks rw
Old 11-02-2013, 09:41 AM
rworegon's Avatar
Here are the locations for the FIPG/RTV for the 5vz-fe 3.4L valve cover gasket replacement:
Old 11-02-2013, 11:13 AM
Thanks a lot!!!
Old 11-08-2013, 03:39 PM
mtrdud's Avatar
Fipg
You can't go wrong with Toyota FIPG
smthwsn357
05-01-2024 07:28 AM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Valve cover gasket question
