V8 4 Runner swap
#41
Originally Posted by SEAN_at_TLT
FWIW, Toyota is offering a manual behind the 4.7L in some 2005 Tundra's...
my guess would be an H151F or similar heavy tranny...
#42
If the R150F can handle a supercharged V6 making ~300HP then I'd think they are up to the 4.7L stock but that's just a guess...
I'd like to see a burlier tranny in there.
#47
as you can see, bell housing covers up half of the front drive flange.
I am going to make a new transmission cross member. With a body lift, it should leave enough room for my radiator and the regular engine fan.
#48
all of the v8 swaps i've seen in person were on SAS'ed trucks, so this wasn't an issue. my plans are sas, then small block chevy swap, but...dodge is different.
#54
#55
Guest
Posts: n/a
Originally Posted by 3yotys
V8's have a good sound. Besides that, you can pull heavy stuff with a V8 you can't pull ˟˟˟˟ with a turbo 4cyl.
#56
you want HP?I got a 496 bigblock making 650HP on pump gas!2jz would be cool,but i aint got one.You ever tried setting valve clearances on the 2jz?Never again!3vze's are bad enough.
#57
Flamedx4,your right,i wanted it to be a little simpler,but i new better.I will have to build an oil pan,use a 3in bodylift, and find another T/C,the current one is a left hand drop.The stock exhaust will almost fit,but a hair too wide.Actualy the 5.2 is narrower than the 350.i'll send yall more pics.
LOL, I get ya.
I, and a lot of folks, wish there was just a simple bolt in "kit", but there are too many variables and always something to fab. There are some parts out there that really help doing swaps, but you kind of have to love it for the hobby it is. Although there are a couple of guys here that have successfully done swaps and had no clue whatsoever when they started (and not much clue when they fiinished in some cases. ;-) , but they stuck to it and got er done! Good on 'em!
#59
well i got the body lift installed today.3 inches looks cool,but i dont think theres enough room for 5.2 exhaust.we'll see in the morning.needs tires and wheels now,sticking out the side,32's will clear.
