Upper BJ Snap Ring Not Seating
Old 04-25-2012, 04:53 AM
MunkeyTX's Avatar
I'm soooo close to finishing up the front end refresh on my '98 4Runner, but the upper ball joints have been the bane of my existence!!
I'm pressing the new upper BJ's in via CajunTaco's method of using a modified pitman arm puller, as a pusher.
The BJ looks to be fully seated into the spindle, and the pitman arm puller is actually beginning to bend the 'ears' of the spindle adjacent to the UBJ hole. The snap ring will seat into half of the circumference of the UBJ groove, but the other sides next to the ears will not.
I cannot apply any more force to the puller, as the tip is eating into my 'pushing pad' and bending the metal.
I'm tempted to just leave it as is, tighten the castle nut to spec, and forget about it.
What would y'all do??
Old 04-25-2012, 10:30 AM
Jay1's Avatar
Is the ball joint sitting flat? When I pressed mine in they didn't sit flat infill I cleaned the mounting suffice.
Old 04-25-2012, 11:14 AM
MunkeyTX's Avatar
Maybe 1/32" off from truly flat...but then again that could be coming from the ears being bent.
While the BJ was being pressed it looked very good, straight all around. I stopped many times to make sure that it was as striaght as possible.
I'm thinking about picking up a 3-jaw press and seeing if changing the mounting points from two large ones with the modified pitman arm puller, to three small ones, will make a difference.
Marsheen
02-17-2016 12:29 PM
nick9455649
08-29-2015 02:08 AM
accuracy
08-06-2015 12:32 PM
kirkrunner
07-27-2015 07:59 PM
KyleT
07-21-2015 07:54 PM
Quick Reply: Upper BJ Snap Ring Not Seating
