Trouble getting into 1st gear
Old 12-03-2004, 12:13 PM
MorphiasX's Avatar
Ok, sometimes when im driving and im coming to a stop, it has trouble getting into first gear, I really have to push on it sometimes to get it to go into first. It is a real pain in the ass. I pulled the shifter and looked at the shift seat, and it appears to be ok, its not shattered or broken at all, the only thing is that it has like small little grooves in it, but they dont seem serious. The only other thing i can think of is the synchros. Is there anything i can do to correct this?
Old 12-03-2004, 01:46 PM
kyle_22r's Avatar
just a typical toyota thing...both trucks i've owned didn't like to go into first gear until you stop. probably the synchros.
not much you can do without rebuilding the tranny($$$), maybe try and find some redline MTL gear oil, which is supposed to be great in toyota trannies
Old 12-03-2004, 09:57 PM
Silver_Truck's Avatar
Try pulling it into second before you stop and then put it into first, it usually helps in getting it into gear.
Old 12-03-2004, 10:03 PM
jimbo74's Avatar
may also bee worn shifter bushings... do a search on it... also might want to look into GM Synchromesh, form otehr forums, it has been said its superior to the regular API GL type fluids
mskalmus
05-28-2017 07:51 AM
HollieJayyy
08-09-2015 07:59 AM
91yotapup
07-27-2015 07:19 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Trouble getting into 1st gear
