Transmission won't hold in any gear
Old 10-27-2012, 08:30 AM
vasinvictor's Avatar
1998 3.4 and a340f automatic in my '95 4Runner. I can crank the auto trans lever down into 1st, but it will shift out just like normal. Won't hold in 1st or 2nd. O/D lockout works. Any ideas?
Old 10-28-2012, 09:32 AM
Transmission threads are always the least popular...
Old 10-29-2012, 02:18 AM
KZN185W's Avatar
could be that the tranny is a goner. Did it come from donor vehicle with S/C? If it did, and the valve-body wasn't upgraded, then most probably the tranny needs to be rebuilt.
Old 10-29-2012, 05:51 AM
BigBallsMcFalls's Avatar
the one shift in a transmission that is all mechanical, is shift to 1st gear
it is a guarantee...so your problem might actually be very simple
something broke or snapped or a linkage is messed up
Old 10-29-2012, 06:00 AM
Thanks for the input. I wired up this swap myself, so another guy in the 3.4 swap section suggested some wiring to look at. After looking over my adapter harness I didn't wire up the L and 2 on the transmission to ECU. It's an electronically controlled transmission and L and 2 have their own positions in the ECU plug at e12-1 and e12-10. The linkage is all good, but apparently it needs ECU input to hold in 1st or 2nd. I'll try to report back, but it's looking electrical, and something I caused.
smthwsn357
05-01-2024 07:28 AM
mskalmus
05-28-2017 07:51 AM
Tykiller1994
08-10-2015 07:49 PM
mengquis
07-13-2015 10:39 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Transmission won't hold in any gear
