Which Transmission do I have?
Old 03-01-2004, 07:36 AM
jwahaus's Avatar
Is there an easy way to determine which transmission I have on my
2002 Tacoma 3.4L automatic?
I've got the Toyota Serivce Manuals (on CD) and there appears
to be 3 possible auto-trany's that could be on my truck.
1. A340E
2. A340F
3. A44D
The manuals show diagrams with both the 3RZ-FE and 5VZ-FE engines
attached so the size engine you have doesn't seem to be the determining
factor.
Perhaps there is a label somewhere I can look at?
Old 03-01-2004, 07:54 AM
mt_goat's Avatar
1. A340E
2. A340F
3. A44D
factor.
Maybe the drivers door jam has a code.
Old 03-01-2004, 09:19 AM
tomstin's Avatar
As I recall, it's stamped on the A/T, passenger side above the pan.
Old 03-01-2004, 09:41 AM
ElwayLite's Avatar
What are the differences between the 3?
Old 03-02-2004, 03:51 PM
AverysDad's Avatar
1. A340E------2.7L or 3.4L 2WD
2. A340F------2.7L or 3.4L 4WD
3. A44D-------2.4L 2WD
Old 03-02-2004, 04:14 PM
ElwayLite's Avatar
So is the A340E the electronic with the power button?
Old 03-03-2004, 01:09 PM
AverysDad's Avatar
do you mean the ECT button?
i thought they all had those..........as far as i know the main difference is that the 4WD model has a built in transfer case (as in you cant seperate them to do a double t-case setup.......but i could be wrong)
Old 03-03-2004, 03:19 PM
My99's Avatar
Off-topic, i'm sorry, but where did you find the tech manual(s) on CD, what vehicles do they cover?
Old 03-04-2004, 07:40 AM
jwahaus's Avatar
Great, thanks. You would think this sort of info would be in the
service manual. If it is, I couldn't find it.
I wanted to know how much of my trany fluid was replaced with
a drain and fill. With the A340F I have, it looks like not much.
Here are the fluid capacities (for anyone that may want to know):
A340E - 7.6 qt capacity (drain removes 1.7 qts) 22%
A340F - 10.7 qt capacity (drain removes 2.1 qts) 20%
A44D - 6.9 qt capacity (drain removes 2.5 qts) 36%
Old 03-04-2004, 07:49 AM
jwahaus's Avatar
I bought it off e-bay for $24 + $6 shipping.
It appears to be an "official copy" as the actual original PDF's used to
print the service manual are included, not scanned-in copies.
The great part is that since the files are originals you can search them
for key words. The part that sux is that there is no Table of contents or
index, so you must search to find anything.
The disc I have is specific to 2002 year Tacoma's.
Old 03-07-2004, 02:19 AM
Transdude's Avatar
Hey guys,
I read this when it first came out a few years ago, but just stumbled upon it again on the web.
It's an interesting overview of evolution of the A340 series of transmissions that is pretty accurate, for the most part.
http://www.transtec.com/rebuilder_news/1st_q00r-n.pdf
-John
Old 03-07-2004, 11:46 AM
jwahaus's Avatar
The manual seems to be a bit off on the drain and fill ATF capacity.
I measured how much came out of my A340F and it was 3.5 qts.
Now it may have been a little overfilled from the drain and fill I did
last week but I think at the proper level at least 3 qts drain out.
This boosts the efficiency of a drain and fill to at least 28% on the A340F
assuming the capacity is correct.
I've done 3 drain and fills on the tranny over the past 2 weeks. I'll likely do
1 more next week and then feel pretty good about the condition of the
ATF. I know that this method is still not as good as a flush of the system
but I feel it is the next best thing.
Cost savings: $150 (dealer charge for flush) -vs- $11 (case of 12 qts ATF)
Old 03-07-2004, 12:13 PM
ElwayLite's Avatar
Originally Posted by Transdude
Hey guys,
-John
Thats pretty neat, glad to know its a well built tranny.
TheBFA
02-15-2020 06:55 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
Odin
09-26-2015 06:56 PM
toyotasaurus
09-24-2015 03:30 PM
briholt
09-20-2015 10:26 PM
Quick Reply: Which Transmission do I have?
