Old 03-31-2016, 03:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner 4WD - Four Wheel Drive Guides
Print Wikipost
Transfer case 4wd Actuator probs: multimode
Old 06-26-2009, 03:05 AM
ash-ssrg's Avatar
Hey Folks,
Got a MASSIVE problem! Been t/shooting my 4wd multimode system (Goes into Locked centre diff when I hit the 4wd switch for UNlocked centre diff 4wd - flashing lights)
Anyways - I opened the actuator on the transfer case to check the terminals, and thats when the ROTOR/SOLONOID/MECHANISM/THING popped out.
I figured out how to get it back into the actuator assembly (by undoing the actuator assembly & sliding it out on the shaft a bit first).
BUT, the rotation of this thing seems critical. Anyone done this successfully before????
Please help.
ASh.
Old 06-26-2009, 03:30 PM
ash-ssrg's Avatar
Originally Posted by ash-ssrg
Hey Folks,
Please help.
ASh.
Some pics of the lil' b@stard
Attached Thumbnails Transfer case 4wd Actuator probs: multimode-actuator2.jpg   Transfer case 4wd Actuator probs: multimode-actuator1.jpg
Old 11-03-2009, 10:58 AM
kennyyoung's Avatar
Ash, is this the actuator motor that you have in your hand or is it the internal parts of the actuator? I am planning on taking my actuator motor off and wondering if there will be a problem with this?
Old 11-07-2009, 02:22 AM
ash-ssrg's Avatar
Sorry for the late reply - I don't know if tacomas have the exact same 4wd actuator as 4runners, but what you see in my pics is the contents of the actuator. This solenoid is a complicated bit of kit (a Chinese puzzle) that could easily pop out when you undo the 3 bolts because it is spring-loaded.
The trouble is knowing what angle it needs to go back in at (getting it back in at all is a mission on its own).
Also, the solenoid seems to have 'in' and 'out' position and I dont know what the default position is.
To make it worse, there are no tech/Toyota guidelines on refitting this. Its 'replacement only' of the whole actuator assembly involving opening the transfer case.
I recommend NOT opening it and check all your diff switches first (if not done yet).
Otherwise, getting another transfer case at the breakers/scrapyard could save you heaps of aggravation.
Another option is to check your actuator motor (insde a black cap on the actuator with 3 screws).
But I have no info on this other than it turns a screw inside the actuator that turns the solenoid. This MAY be your problem.
Check all electricals first
Good luck - keep me/us posted
Old 11-07-2009, 06:43 AM
kennyyoung's Avatar
Thanks ash, for your reply....just in time too! I was just about to go outside and pull the thing apart. I was checking here for any last suggestions and lucky you posted just in time to give me the heads up!!!! Did you ever get your back together and working? Well, I couldnt get the actuator motor off because 1 of the 3 screws wouldnt come out....... I got 2 out with vise grips but cant get at the last one!!! I'm thinking about taking a chisel to it and hoping the remaining 2 will be enough to hold it in place. I figure if I can get at the stator inside the cap, I might be able to free the internals up by turnig it. I really dont want to open the main actuator body if I dont have to. I'm just wondering if anyone knows if they are the same on the Tacoma as the 4Runner?
Old 11-10-2012, 03:35 PM
ash-ssrg's Avatar
Fellas,
sorry - for late reply. A lots been going on since I posted about this problem a couple of years ago -life happens...
We moved from the UK back to Cape Town end of 2009 - shipped our cars down as well - still going strong.
I never did get the actuator to work, despite many hours of free time spent - fortunately/unfortunately, in 2010 my radiator/oil cooler got damaged and allowed coolant into the transmission and transmission oil into the radiator.
Needles to say, the box didnt last long after that...
They never did the 4runner/surf models in South Africa, so it was a miracle that I found a secondhand transmission/t-case on my (cape Town) doorstep - at an engine importer who had a kz-te motor with the transmission/t-case still attached. They would have sold the transmission/t-case for scrap as no-one here would have wanted it - except me!
practically got the transmission/t-case for free, popped it in and have had a perfectly working 4wd system ever since.
Cutting to the chase - a forced transmission/t-case replacement solved my 4wd system nightmares.
4x4-runner
12-27-2016 01:58 PM
Chumlee780
11-13-2015 03:18 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
yourrealdad
07-29-2015 11:08 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Transfer case 4wd Actuator probs: multimode
