Trans interchange?
Trans interchange?
Can anyone tell me what years of auto tranny's I can use in my '01 Taco?
From what I've found, the 01-02 models are different from the older models, and the 03-04's, as well. I can see why the newer ones won't work, since they're electronic instead of cable, but what about the older models?
Which engine?
BTW all the info you guys need has been asked and answered a few hundred times, on this forum and others......
I can point you in the right direction, but google will be your best friend.
Is it going to stay 2wd?
3.4L options are
R150 5 speed 2wd
R150F 5 speed 4wd
A340E 4 speed auto 2wd (I believe)
A340F 4 speed auto 4wd
Weather or not there are others, I'm not sure right off hand.....this is off the top of my head.
Edit:
Just found this thread too, didn't read it.....
This is a good section to read through also.....
https://www.yotatech.com/forums/f160/
3.4L options are
R150 5 speed 2wd
R150F 5 speed 4wd
Edit:
3.4L options are
R150 5 speed 2wd
R150F 5 speed 4wd
Edit:
3.4L options are
R150 5 speed 2wd
R150F 5 speed 4wd
Edit:
BTW thanks for the link.
Don't know if the driveline will the correct length either.
Odin
09-26-2015 06:56 PM
icentropy
09-10-2015 05:03 AM
