total ball joint failure
Old 12-15-2012, 05:34 PM
Sandman's Avatar
my 99 4runner lost her lower ball joint today and popped the whole wheel off. I had no typical warning signs, she was driving smooth and straight before this happened. what a pita! check your ball joints!!!!!
Old 12-15-2012, 05:39 PM
ThatGuy1295's Avatar
You and all these guys. Thats sucks man.
https://www.yotatech.com/forums/f2/t...ilures-244804/
Old 12-15-2012, 05:41 PM
And these poor souls
https://www.yotatech.com/forums/f28/tundra-catastrophic-balljoint-failure-258350/
Old 12-15-2012, 05:46 PM
rworegon's Avatar
Bummer. Since they seem to give little to no advance warning before failing, replace them as PM, at say 10-12 years....the lower BJ and bolts are cheap to replace relative to the consequences.
Sandman, how many miles on them?
Old 12-15-2012, 05:51 PM
aa1911's Avatar
oof!
going to check mine first thing tomorrow to make sure they're still holding together. Used tons of blue loctite and torque wrench to spec but it is still on the back of my brain often times...
yikes!
Old 12-15-2012, 05:54 PM
DRCOFFEE's Avatar
You need to unload them before you can check them. Lift from directly underneath the joint. But if you have more than 100k miles, I would just replace them.
Old 12-15-2012, 05:57 PM
Sandman's Avatar
not sure what the mileage on the ball joint is - I got the truck in 2008 with about 125k miles on it - it's up to 190k now and I haven't touched them...
Old 12-15-2012, 05:58 PM
Sandman, how fast were you going? Looks like your fender is salvageable unlike some of those guys.
Old 12-15-2012, 06:02 PM
Sandman's Avatar
Thankfully I wasn't going fast...maybe 30 mph
Old 12-15-2012, 06:05 PM
rworegon's Avatar
Right in the mileage range where other original ones failed.....
Hope there is not much other damage under there. Definately change the left side now, lower and upper.
Old 12-15-2012, 06:11 PM
Sandman's Avatar
..another view...
Old 12-15-2012, 06:13 PM
thebeeler's Avatar
Same thing happened to my buddy's taco. His ball joint was fine tho only 150kmiles, the bracket that actually holds the ball joint snapped.
Old 12-15-2012, 06:14 PM
rokblok's Avatar
Geez, kinda makes me glad to have a solid axle pickup, and early IFS Runner...
That would just suck to have this happen. Although I tend to maintain my trucks, and check for loose stuff that could kill me....
Old 12-15-2012, 06:20 PM
Sandman's Avatar
i guess I dropped the ball.....joint this time!
kawazx636
10-06-2021 03:03 PM
4x4YOTA
08-23-2016 09:08 AM
hiluxinargentina
09-30-2015 05:51 PM
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
Quick Reply: total ball joint failure
