Tires - 265/70 vs. 265/75 - honest opinions wanted
Old 05-05-2004, 12:44 PM
  #41
Guest
4RUNR's Avatar
You are correct, its called the "moment of interia" in physics.
Additional rotational mass will take away from acceleration. That is what I was trying to say all along.
True, but decrease in acceleration and stopping is not due to the extra weight but by far rather due to the increase in diameter.
How can I break this down: ok let equalize the real cause, imagine 1 foot tall wheels and 10 foot tall wheels on a vehicle, both types of wheels of equal weight, with same rotational force applied to either. Even if the 10 foot wheel weigh nothing it would still be much slower. Overcoming few pounds extra per tire is insignificant comparing to overall vehicle weight.
Old 05-05-2004, 01:06 PM
  #42
rimpainter.com's Avatar
Not trying to nit pick semantics here, but either what I said is a factor or it isn't. I agree that the increase in diameter plays a far greater role in loss of acceleration, but the additional mass of the tire also makes a difference, even if it is slight.
My main point was that friction, rotational mass, and overall diameter are the parasites of our acceleration and MPG losses when going from 265/70’s to 265/75’s.
Old 05-05-2004, 05:41 PM
  #43
PistonSlap's Avatar
Are you saying that I should be able to go zero to 60 in 3.0 seconds and get 80 mpg if you were to switch to 155/80 13s?
Old 05-05-2004, 06:57 PM
  #44
aowRS's Avatar
Mike,
I just installed a set of 275/70/16 REVOs on my '01 SR5 and absolutely love them. Here is a link to a pic of the setup:
Andreas
Old 05-05-2004, 07:02 PM
  #45
Bob_98SR5's Avatar
Andreas,
Good to see you over here! Looks like you took my advice Did you get the PP 1" too?
Bob
Old 05-05-2004, 07:06 PM
  #46
kford's Avatar
I went from 265/70/16 goodyear rt/s (street tire) to 265/75/16 BFG T/A KO's all terrains and I LOVE THEM. They are my favorite "mod" if you can call it that, they are great in most weather (rain could be better), didn't notice any mpg difference, and no power loss (but I did the ISR and deck plate too, maybe it compensated).
Go with 265/75.
And about somebody rubbing w/ 265/75, that seems kind of weird, mine don't even come close and I'm riding on stock springs and shocks with 265k on them so theyr'e definitely sagging.
Old 05-05-2004, 07:13 PM
  #47
aowRS's Avatar
Bob,
Thanks again for all the email consultations the other month. In the end I opted for a fresh set of '99 4WD V6 coils from Toyota and a set of Bilsteins. The install took around three hours and I now have 18.75" at the body seam, and 36" at each fender lip. Well over an inch from the stock low-rider look I had before! The tires are awesome (well after two days of use...).
Andreas
Old 05-05-2004, 07:25 PM
  #48
Guest
4RUNR's Avatar
The 3.4 is not enough to propel 4000lb 0-60 in 3.0 second, no matter the gearing, but I bet you that with a beefy CVT, revving it up to peak HP and going would be in the 6's
Old 05-05-2004, 07:42 PM
  #49
Yes, that is exactly what I am saying Mr. Wizard.
Old 05-06-2004, 04:52 AM
  #50
goldtaco9's Avatar
Hardeeharharhar!
Old 05-06-2004, 04:53 AM
  #51
goldtaco9's Avatar
Thanks for the pic Andreas. They look great on your rig.
Mike
Old 05-06-2004, 05:02 AM
  #52
4RunnerFever's Avatar
Andreas Link?
Nice ride Andreas. Was there supposed to be some link to follow? If so I don't see it.
cheers!
Old 05-06-2004, 09:17 AM
  #53
aowRS's Avatar
cheers!
No link - just new to the YotaTech posting methodology...
Andreas
BushPig
10-29-2022 06:26 AM
A2theK
07-12-2015 10:46 AM
msane99
07-11-2015 08:08 PM
87blyota
07-08-2015 09:16 AM
Quick Reply: Tires - 265/70 vs. 265/75 - honest opinions wanted
