Tire Size Clarificaton for 2nd Gen
Old 01-28-2003, 10:33 AM
Hokiez97's Avatar
Hi all,
I was checking on my rig (95 4runner Limited 4x4 3L, AT) and noticed that the door frame says this--------
225 75 15 = (small rubber bands for tires)
Vin Number
VZN 130L-GKPGEA
C/TR 2K3/LP44
A/TM G144/A340H
Manufactured in 2/95
I also have a first gen that says the same tire size.....
CORRECT ME IF I AM WRONG................
Didn't the 4WD 4runners come standard with 31 10.5 15's after a certain year.
I know that there are different speedometer gears available for the 4x4 trucks...depending on the size tire you have.
So my question is - Is this sticker always right for what came on the vehicle....???????
What the heck do the other numbers on the above sticker stand for? I see AT trans and some other mumbo jumbo.
Thanks everyone,
Mike
:wtf:
Old 01-28-2003, 10:37 AM
az4x4runner's Avatar
The sticker on mine says 225/75-15 too, but I have stock 31's, the G144 after the AT thing is your gearing, G144 which happens to be what I have as well are 4.88's.
(Check out this webpage: click )
Old 01-28-2003, 10:45 AM
Co-Founder/Administrator
Staff
Corey's Avatar
This page here is suppose to tell you by the #s that are on your door what gears you have.
http://www.off-road.com/toyota/tech/other/4_axles.html
Not all 2nd gens or '89 to '95 trucks came with 31s.
My '90 Extracab 4x4 came with the puny 225 tires and fugly silver steel wheels.
My 4Runner also came with the small tires as the spare tire is the smaller one.
Some rigs that came brand new from Toyota with the 31" tire package also states on the door jam that it came with 225s.
The 31" tires were an option that you paid more for.
Old 01-28-2003, 01:37 PM
Victor's Avatar
That door sticker is a generic sticker the factory slapped on every truck no matter what option package came with the truck. If you have the factory aluminum rims and 31" tires you probably have 4.56 gears if it is a 5 speed or 4.88 gears if its auto (lucky bastards!). Just use Cory's link to figure out your gear ratio. The numerically higher gears (mechanically lower) were only offered with the larger tire package as that was an option.
Old 01-28-2003, 02:30 PM
94 First Responder's Avatar
if your a limited i think 31s were standard. Mines would have been a limited if it came out in 95. I have 5spd with 4.56's.
Old 01-28-2003, 04:40 PM
gwhayduke's Avatar
My 95 5-speed came with 4.56 and 31". It would undoubtedly be a little more peppy with the 4.88's but I'm runnin' what I brung.
06-01-2021 01:51 PM
djpg2000
11-11-2020 04:56 AM
coffey50
07-28-2015 10:55 AM
Yotoder865
07-09-2015 07:51 PM
Steezy96yota
07-06-2015 10:00 AM
Quick Reply: Tire Size Clarificaton for 2nd Gen
