Throttle Body A/T vs. M/T
Hello,
I am purchasing a new throttle body for my 1996 Tacoma as mine is worn out.
From viewing this website: http://www.woodfins.com/Parts/1996-T...le%20Body.html
It looks like you can order an a/t or m/t throttle body. I was unaware that there was any differences?
Is every 5VZFE throttle body the same for the same year?
Thankyou
Thankyou
haha.. unfortunately my butterfly valve has a gap from the cylinder bore allowing extra air thru increasing my idle. Yep I guess metal on metal does wear out eventually even if it is yota!
turbo8 sometimes the high idle after tb cleaning is caused by all the junk and cleaner running down into your IAC which is underneith the TB. Thanks for the high temp silicone tip. Do you see any problem with the silicone wearing off and going in to the engine?
I am getting another TB from the wreck yard for $60. Hopefully that should fix it.
06-01-2021 01:51 PM
Blamalam
08-16-2015 12:29 PM
