Testing Idle air controll valve
Old 01-21-2008, 05:27 AM
merace19's Avatar
I need to know what the readings for a 2000 tacoma IAC should be? My truck has high idle and i believe that the valve is the problem. I have a reading from the RSC to B+ of 60 ohms, and RSO to B+ of 5 ohms COLD. When I put 12v+ to the B+ and Neg- to the RSC it only twitches the flap a little. But when I but 12v+ to the B+ and the RSO it does nothing. The valve is 229plus tax so I dont want to just replace it it if I dont have to.
Old 01-21-2008, 06:24 AM
pineapple's Avatar
I'm looking at the FSM for a 99 Taco. for the 3RZ-FE the resistance is listed as:
COLD:17.0-24.5 ohms
HOT: 21.5-28.5 ohms
for the5VZ-FE:
COLD:17.0-25.0 ohms
HOT: 21.5-29.5 ohms
Old 01-21-2008, 06:35 AM
pineapple's Avatar
There is a thread listed as 'starting problems' I posted with responses to the IAC that you might check out. Good Luck.
Old 01-21-2008, 07:42 AM
MTL_4runner's Avatar
According to the 00 FSM:
"Using an ohmmeter, measure the resistance between terminal +B and other terminals (RSC, RSO).
Resistance:
Cold 17.0 – 25.0 ohms
Hot 21.5 – 29.5 ohms
If the resistance is not as specified, replace the IAC valve."
So from what you tell me your readings are, you should be replacing it.
smthwsn357
05-01-2024 07:28 AM
Charecter1
11-06-2023 10:08 AM
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
coryc85
09-09-2015 06:24 AM
Quick Reply: Testing Idle air controll valve
