Tailgate Latch Return
Old 01-10-2010, 04:08 PM
934rnr's Avatar
Ok well after a day of hammering prying and cut wrists from moving around in a tight area it still does not open.....
I am pretty fed up I think I might have to take this to a stealership. The latch will not release at all.
Old 01-11-2010, 02:18 PM
934rnr's Avatar
Well I got it open. It basically opened all by it's self kinda at a bad time coming down the ramp in the parking garage.
I was transporting 8 dell pc's from downtown to the hospital where I work.
Luckly the rear cb antenna kept it shut. It was 1/4 open.
Maybe spraying the the cooking pam down on the lock mechanism helped some....
I'll tell you in a pinch if you have no wd-40 or lube available Pam cooking spray works really well...
Anyways off to the dealer for the pricey $147 lock latch.
Old 05-22-2010, 02:22 PM
marmotan's Avatar
HuskyRunner, how is the latch fix working for you now that it's been a few years? Mine is having the same issues and I'm contemplating installing a new latch assembly like you did. They are available at toyotapartsbarn.com for $93+shipping.
Old 11-26-2014, 05:12 PM
Cinn's Avatar
Awesome info on here.Thank you guys.I sure am not giving up on getting this back hatch fixed by me.I was given a quote of 500 dollars to fix it .After reading your post I believe I can save some money with patience and take my time.Thanks again.
Old 05-12-2017, 03:00 PM
  #25
Patricia Herrera's Avatar
WD 40 worked, we cut the rest of that stupid shredded up rubber off to
kawazx636
10-06-2021 03:03 PM
I8URSVT
03-02-2021 06:23 AM
matmattmatthew
10
02-09-2021 04:15 PM
1uzRunner
63
11-10-2018 03:58 PM
punks_is_4x4
09-19-2015 05:52 AM
Quick Reply: Tailgate Latch Return
