Tacoma stock height?
Old 04-08-2005, 06:10 PM
ianshoots's Avatar
Hey gang, my trucks suspension was beat when I got it, so I'm curious How much higher than STOCK, as opposed to 8 year old stock, I am. I don't figure it changed much 95.5-04, so can someone tell me the stock height, front and rear (at the wheel-well would be cool, or bumper) of V64WD (xtra cab if makes a diff) tacoma, anything from those years. The rear starts out higher, right?
(BTW, I did do a search, found heights for a bunch of gens of runners, and on older truck, but no tacos).
spanks,
Ian
Old 04-08-2005, 06:56 PM
Tacoma Dude's Avatar
You're in luck!
I just found this the other day.
I went to the local dealership a few years ago and wrote down what the stock height (peak of wheel well from ground) was on a double cab V6.
Driver front - 35"
Driver rear - 36.5"
Passenger front - 34.5"
Passenger rear - 36.4"
I didn't get a chance to check out the tires' PSI so these may be off what they are supposed to be. Hope it helps you out!
Old 04-08-2005, 09:24 PM
ianshoots's Avatar
Thanks Tacoma Dude!
Thanks man, sounds like tire pressure was a little low. Mostly I wanted to know how much higher the back is stock-I'm about done with my lift and it looks like it will be about 1.5 to 2" higher in back (without the cap or spare or hi-lift), so it seems like the front to back ht. diff will be close to stock.
I'm okay with the back being a little higher empty, I haul stuff quite often (lumber, quikrete, firewood, dogs, etc) and it'll be nice not to bottom the springs out everytime I load up.
Last edited by ianshoots; 04-08-2005 at 09:25 PM. Reason: can't type after midnight
Old 04-08-2005, 09:35 PM
I don't know about everyone else but I like seeing the back end a little higher than the front end. Funny since my rear has leveled out and I'm pretty much even now.
Old 04-09-2005, 09:59 AM
CynicX's Avatar
i just measure my 04 with recommend tire pressure and the tires being cold...
front 35 1/4"
rear 36 1/4"
Old 04-12-2005, 07:36 PM
ianshoots's Avatar
front 35 1/4"
rear 36 1/4"
Do you have 31's?
thanks,
Ian
Old 04-12-2005, 07:37 PM
ianshoots's Avatar
Also, now that the lift is on, I'm mildy worried that the front is too high, but I think its okay.
Old 04-12-2005, 08:24 PM
CynicX's Avatar
Originally Posted by ianshoots
Do you have 31's?
thanks,
Ian
well it has the stock equivlant to 31's.... 265/70/16
Old 05-01-2020, 11:34 PM
Leviavans's Avatar
1997 taco
Is the stock ride hight of a 1st gen taco single cab, 4or going to be the same ride hight as the extended cab?
Flying91
45
04-11-2024 04:39 PM
TURBOrunnerNM
07-20-2015 08:31 AM
94whiterunner
07-12-2015 07:15 PM
Poncho0206
07-10-2015 06:21 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: Tacoma stock height?
