Tacoma Leaf Springs!
Old 02-10-2005, 07:36 PM
98_YOTA's Avatar
Got a 98 Tacoma 4x4, with sagging rear end due to weak springs.....will springs off a newer tacoma work (Length, width) I dont have the funds right now to buy aftermarket springs so just trying to get by with some used ones......please let me know thanks guys!
Old 02-10-2005, 07:49 PM
humanoid's Avatar
Yeah, '95.5-'04 should fit. I got a set from an '02 about a year ago, but need to get off my lazy @$$ and bolt them up.
Old 02-10-2005, 09:00 PM
98_YOTA's Avatar
THANKS!
Old 02-11-2005, 05:47 AM
GodwinAustin's Avatar
I beleive the 95.5-97 are different sizes.
Stick with 98+
Old 02-11-2005, 05:48 AM
TacomaTRD's Avatar
you could try looking into doing a "add a leaf" at a local spring shop. This will also give you more load capacity...
Old 02-11-2005, 02:46 PM
Intrepid's Avatar
Spring length
I would be a little careful, make sure you measure. I replaced the rear leafs in my 98 tacoma and when I was looking around everyone said they could get 51" I think was the length. The problem is that mine were 53" and I didn't want to move the perches.
Old 02-11-2005, 02:56 PM
SEAN_at_TLT's Avatar
I would suggest getting Deaver's triple add-a-leaf pack. It is a kit that consists of three leaf springs that replace the single large factory overload leaf and in the process makes the rear suspension more progressive and also provides about 1-1/2" of lift. The triple pack goes for about $150 and is easy to install in about an hour or two. You can buy a set from Kartek, Donahoe or Off-Road Warehouse....
Old 03-06-2011, 01:29 PM
jt100's Avatar
does any one know the length of the leaf springs off a 2005 tacoma? i am looking at buying a pair from someone i know but i have a t100 and im not sure if they are the same length
nvdesertrunner
05-11-2020 08:18 PM
4x4-runner
04-18-2017 09:08 PM
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
88sasturbotoy
08-11-2015 01:56 AM
Greene916
08-10-2015 01:45 PM
Quick Reply: Tacoma Leaf Springs!
