Sway bar question?
Old 06-09-2009, 03:53 PM
Bobs4Runner's Avatar
Sway bar question?
I need to replace my front sway bar bushing and brackets (rusted and one broke). I bought new stuff but they don't come with the mounting bolt. So I went to Lowes and bought the worrect metric bolts that fit, but there not grade 5 or 8, there Class 8 hex nuts and class 8.8 hex cap screws (bolts), are these the same as grade 8? Or where can I get grade 8 metric bolts and nuts?
also where can I find rear sway bar bushings? I want to replace them also.
Thanks
Bob
Old 06-09-2009, 04:34 PM
crolison's Avatar
10.9 metric is more like grade 8.
Old 06-10-2009, 09:31 AM
Any idea where to get 10.9 metric bolts from?
Old 06-10-2009, 09:42 AM
okie81's Avatar
Grade 8 is around, I had to call a few places but finally a mom-n-pop hardware store had them.
Do a search for rear bushings, there's kits out there. I'd recommend the greaseable front bushings though since aftermarket bushings have the tendancy to squeak.
Old 06-10-2009, 04:47 PM
FJHammerHead's Avatar
I've picked some up at Ace Hardware in the past.
Old 06-10-2009, 06:22 PM
Jerm's Avatar
Try Fastenal.
Old 06-10-2009, 06:26 PM
Lumpy's Avatar
Leave it off just slow down around the turns...
Old 06-10-2009, 06:29 PM
waskillywabbit's Avatar
Grade 8 is 10.9 metric, Grade 5 is 8.8 metric
Old 06-10-2009, 06:30 PM
RMA
RMA's Avatar
X2 on Ace Hardware ive found them there also.
Old 06-10-2009, 06:38 PM
Stick_Figure's Avatar
or if you just want to order them www.mcmaster.com will most likely have what you need.
Old 06-11-2009, 04:53 AM
Cool, thanks.
Slow down.....uh no. hahaha.
Bob
Old 06-11-2009, 06:12 AM
TC4RNR's Avatar
better pay some good money at stealership for that kinda stuff. the nut was designed to be self-tighten, like a ny-lock nut but without the nylon washer. it provents the nut backing out while driving. if you decided to use regular hex nut, use a second one as jam nut.
edit:
Ok, I did a little research, actually just flipping through the Grainger catalog happened to be just handy. the type of nut is called "Deformed Thread Locknuts"
"In addition to working as regular nuts, these
locknuts feature irregular internal threads that
lock onto the mating threads of a bolt or rod and
prevent rotation or loosening. Right-hand thread
direction."
you can find it here: http://www.grainger.com/Grainger/wwg/catalogPDF.shtml
then at "go to page: " type in "2530"
the one you need is CONICAL TOP FLANGE
nvdesertrunner
05-11-2020 08:18 PM
4.34runner88
08-11-2018 10:44 AM
coffey50
07-28-2015 10:55 AM
DrZero
18
07-24-2015 11:31 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Sway bar question?
