Surging/Thrusting Problem Under Acceleration
Help Please
Please Help!
I have a 1995 Toyota tacoma 2.4l 2wd truck with 139,000 miles. While driving on the road or the freeway i get this thrusting motion (I guess you would call it a surge) under a load in 1st, 3rd and 5th gear. It usually occurs only when going up a slight grade. If i get up on the gas pedal it will stop or if i down shift and raise the rpms.
For example: while driving on the freeway at 65 mph in 5th gear the truck starts thrusting or surging if i bring the trucks speed up to 75 the thrusting disappears or if i shift into 4th gear it goes away.
The truck idles perfectly now that i replaced a few parts, but the surging is driving me bonkers.
I have taken it to several mechanics and they cant seem to figure it out.
This is what i have done to it so far.
Replaced the following:
Plugs, wires, cap, coil pack, rotor. air filter, oil change, TPS, transducer, pcv, valve cover gasket, fuel pump, fuel filter, clutch kit, changed transmission fluid, replaced a couple of vacuum lines.
I cleaned the throttle body, IAC, MAFs
I get no codes or check engine light what so ever.
I have checked to see if the check engine light works properly and if i disconnect the TPS or MAF the engine light comes on and i also get the codes.
Any help would be greatly appreciated.
88runnergomas
07-09-2015 01:12 PM
