Sunroof cable replacement writeup
Old 01-17-2016, 03:42 PM
AlwaysOffLine's Avatar
A sincere THANK YOU to all the previous posters! Without hassles (i.e., stripped screws), you can have the headliner out in about an hour or less, and the sunroof removed and completely disassembled in under 2 hours. have both a can of electronic tuner cleaner and a can of GUNK spray brake cleaner handy! Once apart, you can pull the cables out of the copper tubes for deep cleaning - you'll need to remove the old, rubberized grease from the cables and the tubes. Using the fine spray straw on the GUNK, soak the copper tubes to removed traces of dried grease. Then, with a metal, deep paint roller pan, coil the cables and napalm them with the electronic tuner cleaner and then the GUNK. Let them soak for awhile, the same for the copper tubes. You'll need a wire brush, but you can do a good job of cleaning the cables!
Old 01-24-2016, 10:28 AM
Garcias91's Avatar
Sunroof disassembly
Originally Posted by rah1420
I have a pdf file from the tech site at toyota that details the moonroof replacement and stuff. it's a little fuzzy with the graphics but it appears to be useful.
I'll mail it if anyone wants it.
Hello I'm actually doing this job soon. Could you mail me the file?
Thank you!!
Old 01-24-2016, 10:30 AM
Garcias91's Avatar
I would love a copy please!
kazuya2416
04-05-2024 02:17 AM
sandyota
02-04-2021 11:16 AM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
shar
07-09-2015 12:38 PM
Quick Reply: Sunroof cable replacement writeup
