Stuck bolts/body lift
Old 07-02-2010, 06:07 PM
AlexXx's Avatar
The bolts in the bed aren't nudging, any tricks on freeing them. It was also my first time using the impact wrench, socket wrench wasn't cutting it. So I might not be doing something right. I usually just work with simply hand tools for everything.
Thanks guys!
Old 07-02-2010, 06:25 PM
Yukon's Avatar
Soak in a 50/50 mix of ATF and Acetone. Supposdly the best stuff you can use
Old 07-02-2010, 06:54 PM
AlexXx's Avatar
Hm well I'll give it a try! thanks!
Old 07-02-2010, 07:22 PM
gary96360's Avatar
my impact wasnt strong enough so i used a breaker bar with a snipe to take off bolts when i did my body lift
Old 07-02-2010, 07:38 PM
scottishb's Avatar
I normally take the breaker bar and a hammer, and start smacking. After some PB, of course. Smack the socket. Smack the bar. Use the force.
Old 07-07-2010, 08:37 AM
Mauzer's Avatar
I did my BL this past weekend (on a runner) and just soaked the crap out of the bolts w/ PB Blaster. I was watching the Paraguay vs Spain match so I sprayed them before, during the half, then after and they came right off using a socket wrench.
by the way...my rig lives in TX now but spent the first part of its life in MA, so its plenty rusty under there and I still got em off w/o complication
Old 07-07-2010, 08:55 AM
yotaluver's Avatar
I used PB blaster and a braker bar cause my impact wouldn't do it
Old 07-07-2010, 09:10 AM
pwd
pwd's Avatar
Its kind of sad, I go through this with almost every bolt, because of the rust.
Old 07-07-2010, 01:47 PM
pattycakes77's Avatar
If using an impact on rusty bolts, be careful you don't break the head off and leave the rest still attached! It's a PITA. I'd just soak them in PB or other concoction and use a breaker bar carefully. I dread removing bolts/nuts from under my 4runner
Old 07-07-2010, 02:29 PM
4Crawler's Avatar
Thanks guys!
Assuming this is a Tacoma, the trick is getting the penetrating oil up where the nuts are, inside the bed rails. Don't just spray the bolt head, because that is not where it is stuck. If you can't get oil up onto the nuts, you might try drilling a small access hole near each nut (the 4 forward mounts) and see if you can get the nozzle/tube on the spray bottle up there. And then let the oil soak for a while, hours to overnight is best.
And you really want to avoid breaking those welded nuts loose from the bed rails, if so, you'll need to remove them and weld in new ones.
Old 07-15-2010, 05:39 PM
AlexXx's Avatar
17mm wrench and hammer did the trick haha, a few good whacks and they came undone. Thanks for all the replies!
westonian18
05-01-2020 06:38 AM
okamikai
04-30-2018 10:19 PM
fountain
12-31-2015 06:08 AM
Motomonty
08-09-2015 05:53 PM
coffey50
07-28-2015 10:55 AM
Quick Reply: Stuck bolts/body lift
