Stereo Wiring Harness - Some leftover wires..
Old 06-18-2008, 02:22 PM
birchy's Avatar
Couldn't find an exact answer by searching.
On the stereo side (Pioneer DEH4600MP) I have a blue/white cable left.. and on the toyota harness side I have a straight blue, and an orange/black and orange/white leftover:
Does the blue/white go to the blue? Will that hurt anything?
Old 06-18-2008, 03:54 PM
birchy's Avatar
Bueller?
I've been sitting home here for like 2.5 hours now with a wiring harness and new stereo ready to install!!
Just need a little reassurance that's all..
Old 06-18-2008, 04:13 PM
HAVOC's Avatar
I think the blue/white is for an amp or power ant. and the orange/black and orange/white are for illumination.
I could be wrong, check this site to find some additional info: http://www.the12volt.com/Default.asp?
Old 06-18-2008, 04:17 PM
86blue4runner's Avatar
The blue/white is remote amp lead. THe orange white is illumination. and not sure about the orange/black, might call pioneer on that one.
Old 06-18-2008, 04:18 PM
PatHLC128's Avatar
if it makes you feel any better i remember having leftover wires too when i put my stereo in...i cant remember exactly which ones they were.
Old 06-18-2008, 04:35 PM
kmrunner's Avatar
Unless you have an amp you are good to go. From what I can tell you have the 12v, accessory, ground and all your speakers connected correctly. Just tape off the loose wires to avoid a short and plug that bad boy in. I think I had the same wires leftover and I just installed the deh5500.
Old 06-18-2008, 04:38 PM
birchy's Avatar
Awesome! Thanks guys!
I love this site..
Old 06-18-2008, 05:30 PM
birchy's Avatar
Okay.. installed and working. Only thing is that my power antenna won't go up anymore when the stereo is powered on.
Old 06-18-2008, 06:27 PM
kmrunner's Avatar
from another yotatech thread
The blue loop allows you to connect stereos that only have one blue color lead easily.
The car end connector has a connection for the antenna and one for amp turn-on. The wiring harness' with a loop connect the two together so the installer doesn't have to remember to tie the amp turn-on and the antenna wires together.
The blue/white wire from the pioneer unit should be connected to the blue "loop" wire on the factory harness.
Old 06-19-2008, 05:36 PM
RobD's Avatar
Dude, lose the crimp connectors and do it right with solder and shrink tube.
Second, the reason your power antenna isn't going up is because you need to hook the blue/white lead to your power antenna relay.
If you need wiring diagrams for your truck, I suggest coughing up the 10 bucks and getting an account to https://techinfo.toyota.com/techInfo....toyota.com%2F and downloading pdf files to your heart's content.
Old 06-20-2008, 05:01 AM
terminator's Avatar
Yep, blue/white and the blue need to be connected to get that antennae to go up and down bro. Fix that and you're good.
Old 06-20-2008, 05:22 AM
Greg_Canada's Avatar
Whatever you do, do NOT hook up the orange/white wire.
Old 06-20-2008, 09:11 AM
fullmann's Avatar
blue/white out of the pioneer harness is amp remote, but for your case it will work as an antenna remote. connect it to the blue of the adaptor harness.
the orange/white is illumination, it turns on and off with your lights, cap that off as it looks like your pioneer doesnt have an illumination circuit. some aftermarket decks do, and therefore I would leave it, just cap it for possible future use.
the orange/black is illumination ground, there is no aftermarket stereo in this universe that uses that wire, go ahead and yank that sumbitch right out of the adaptor harness altogether (or cap it off if you choose)
Old 02-14-2017, 05:07 PM
rocket01's Avatar
Talking
blue wire
Old 02-15-2017, 06:38 AM
birchy's Avatar
Wink
Originally Posted by rocket01
blue wire
ohthankgawd... NINE YEARS i've been driving around with my antenna down...!!!
Holy back from the dead.. I was so confused when I got this email notification last night. Sold the 4Runner like 8 years ago.
theking11863
03-19-2016 09:36 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
TDonkey
07-26-2015 10:14 AM
toofly1999
07-25-2015 07:09 PM
msane99
07-17-2015 10:13 AM
Quick Reply: Stereo Wiring Harness - Some leftover wires..
