steering making noise after starting
Old 09-02-2009, 11:48 AM
Brend2b's Avatar
recently my steering has been making some noise after i start my 4runner. i noticed it about a week ago and it had gotten slowly worse each day. it only happens right after i start my 4runner while the engine is cold. it sounds like the whining noise that you hear when turning the wheel to full lock but it happens with every movement for a few minutes. what is causing this problem?
Old 09-03-2009, 09:44 PM
GoHideTheAsian's Avatar
not enough tension on the power steering or fan belt. well thats what was wrong with mine and got it tightened up, problem went away
Old 09-03-2009, 11:18 PM
brian2sun's Avatar
How's the fluid look?
Old 09-04-2009, 01:13 PM
Brend2b's Avatar
fluid looked fine when i checked before i posted. ill check again see if anything changed
Old 09-05-2009, 12:26 AM
desertcamper67's Avatar
Fluid level was right?
the1998sr5
10-19-2016 12:48 PM
voiddweller
19
05-02-2016 09:10 PM
Bamripzit
07-19-2015 01:17 PM
Bamripzit
07-13-2015 07:21 PM
camdenbuck
07-07-2015 07:33 AM
Quick Reply: steering making noise after starting
