sputtering 2.7
Old 05-26-2007, 07:14 AM
davesborden's Avatar
sputtering 2.7
I have a 2.7 litre in my 97 tacoma. The engine sputters out between 1000 and 2200 rpms. Beyond that range the engine runs great. whats going on? anyone had to deal with this problem?
Old 05-26-2007, 03:25 PM
Skrillah's Avatar
Describe sputtering out?.....
Old 05-26-2007, 04:56 PM
bktaco's Avatar
without any more clues, could be a clogged fuel filter? how many miles? i've had mine for 120xxx, but no problems yet like that.
Old 03-10-2010, 05:12 PM
97taco's Avatar
I have a 97 taco 2.7 4x4 119,000 miles just had high idle and sputtering at all different speeds. I was told possibly two things could cause this by tech at toyota dealer first tyhe EGR valve and second the Trottle positioning sensor I started by replacing the EGR and cleaning throttle body with spray while on truck NO effect at all. Then I took the throttle body off of the manifold and cleaned it right also noticed port in manifold between EGR and throttle body was clogged almost closed with carbon I removed the EGR again and sprayed cleaner thru port and wire pipe brush cleaned it out. Truck idles normal no and does not sputter also much better response.
Old 03-10-2010, 05:13 PM
97taco's Avatar
Hope this helps some others with same problem.
Old 03-10-2010, 05:26 PM
yotafool's Avatar
Hmm... I may have to do this as well because when I took my EGR valve off i noticed a lot of carbon inside the manifold. I temporarily blocked my egr valve off till i can afford a new one because it is stuck open with no saving it. I'll probably wait for a warm weekend in the future and take the manifold completely off and spend a lot of time cleaning it.
Old 03-11-2010, 07:56 AM
97taco's Avatar
no need to take the manifold completely off just remove the throttle body and there is only one port I know of in the manifold and that is on the left side faceing the opening where the throttle body mounts . Once you remove the Throttle body you can put pike cleaning tool right threw it since you have the egr of allready. PS you should be able to clean up the old egr with cleaner
Gutted91
01-03-2020 09:48 AM
Sam hain
19
09-30-2015 08:25 AM
93RedKrawler
09-25-2015 04:03 AM
83
18
09-21-2015 06:15 PM
Gutted91
09-17-2015 05:44 PM
Quick Reply: sputtering 2.7
