!!Speedy's Supercharger Thread!!
#81
Well its the samething Brian was telling you about earler, he calls it a oxygen sensor calibrator or a AFRSC. Here's the link:
http://www.urdusa.com/product_info.p..._id=1230100028
I need to tune mine some more, but in closed loop I'm around 13 in very low boost and more like 12.5 a little higher boost and then jump to about 10.5 in open loop. The ECU doesn't fight with me on the tuning with it, in fact it seems to help.
I know the AFRSC has a map of values in it, are the map's values AFR values (E.G. 12.5:1) or percentage values like in the FTC (E.G. 9.5)? The description on URD's website almost makes it sound like you are able to put AFR values into it (but they could be over-simplifying things...)
#82
I've got a quick question for you Dale-
#83
What year 3.4L motor are you running it on? I assume from the product's description that your motor uses a WB O2 sensor for the ECUs AFR readings?
I'd LOVE to be able to have a 13:1 in low boost (1-2 psi) then go to 12.5 at 3-4 psi, then 11.5-11.8 above 4 psi.
How many miles do you have on the unit ?
#86
#87
Well, I got the truck back. The guy did an awesome job on fixing the studs. He removed all three stock studs (which he said were grade 5 or 6 and break way too easy) and replaced all of them with one size larger grade 8 hardware (looks like a bolt and nut/washer combo). The work looks really good and he said I shouldn't have anymore problems with breaking them as it was now stronger than stock.
#89
Here's some more info about it:
http://www.customtacos.com/forum/showthread.php?t=51193
#90
Humm....well since my last ECU reset all it has done is get better. The guys I've seen that have to reset the ECU to keep the closed loop ratio right are just running an FTC and didn't have the A/F sensor Cal.
My confidence is slowly coming back after this $300 exhaust stud issue. That's still burning me a little.
#91
I can feel a difference in about 300-400 miles. I've actually wired a momentary pushbutton into the ECU constant power lead so that I can reset the ECU from inside the truck instead of having to pull the fuse.
#92
And do you have an AFR gauge to actually see the AFR changing from what you have set it to in closed loop?
#93
#94
A local tuning shop said Toyotas are notoriously hard to tune because of this very reason. He said the factory ECUs are stubborn.
Here's a thread from TTORA where a guy had issue with the AFR calibrator:
http://www.ttora.com/forum/showthrea...AFR+Calibrator
The tuning shop ended up removing it to get the engine tuned. They ended up setting him to 14.7:1 in closed loop, meaning even under boost he's 14.7:1. You guys know how much research I've done, and I haven't found anyone successfully get anything but 14.7:1 long term in closed loop. Hopefully being forced into 14.7:1 in closed loop boost is not too detrimental to engine longevity.
#95
The short form is that I have had HORRIBLE results from the SplitSecond spoofing boxes, specifically the ESC1. I've been pretty vocal in public regarding how I feel about them and the "leading supplier of SplitSecond products in the Toyota truck community".
I alluded to it in a previous post here in your thread, but I was asked in a PM to retract the statement. Drop me an email or PM if you'd like details.
So you're setting your AFR to what value, and what value is it 300-400 miles later?
https://www.yotatech.com/forums/f2/got-s-c-piggyback-wanna-try-something-77040/
note: This is _without_ using anything to attempt to fake out the O2/AFR signal. See above for my feelings on the spoof boxes.
#96
I'm getting kind of lost here. Either it's OK to run 14.7:1 in closed loop or it's not. If it's not, then what's the point of doing a SC to begin with if this value pretty much can't be changed? If it is, then you just live with slightly reduced power in closed loop, and tune for open loop to be 11.5 or so.
Seems like that other thread you referenced started suggesting that tuning Open loop affected closed loop? That confuses me as I thought once you were in open loop the ECU no longer monitored AFR.
#97
If you intercept the MAF signal, you can create a state where you can create a rich mixture. _In my experience_ this is a temporary change, because the ECU will continue to try to push that mixture back to Stoich (14.7:1). From that other thread, it looks like other folks have seen this happen as well - and some have not. It's VERY evident on my truck.
To combat the ECU doing that, the theory is that you fake the ECU into thinking that the engine is already running at 14.7:1 so that it won't adjust the mixture. This is the marketed purpose of the ESC1 and other boxes. And this is also where I (and a few others) have different feelings between "marketed hope" and "reality".
My statement that you quoted is in reference to my NOT running the ESC1 (or equivalent) but I _am_ running the SMT5 which is hooked up to allow me to adjust fuel deliver by modifying the MAF signal.
You want to tune Closed Loop in order to create a smooth transition in terms of fuel flow on the way to Open Loop.
There are a number of ways to force more fuel at open loop, and "we all" know that we're aiming for something pretty rich, 12:1 or so. If you come up onto the point of open loop with a Stoich fuel mixture, and then all-of-a-sudden you start dumping fuel, the engine will stumble while the timing gets advanced to keep up. In order to combat that, "it would be nice" to be able to tune in closed loop so as to make the transition more gradual.
Now, there is inevitably some crossover between Open Loop and Closed Loop around the fringe area of the tuning tables. There are only so many slots, and they're not very granular. As such, you can easily find a cell in the table where, depending on other things going on, you could be in Open Loop _OR_ Closed Loop. In that case, you'd want to tune the cell for Open Loop.
#98
Finally...you had some engine issue a while back. Was that due to a lack of fuel mods, or did you have fuel mods and STILL experience the cracked head? Any ideas what caused that?
#99
I presume the 14.7:1 in closed loop under boost is "ok" from a motor stand point?
http://en.wikipedia.org/wiki/Stoichiometric
http://www.taftan.com/thermodynamics/COMBUST.HTM
We never really looked at trying to tie the cracked head in with the high temps - the crack could have been there for quite some time.
#100
Thanks for all the info. I'll have to keep digging on this. I've got 75% of the system setting in my guest bedroom now (SC, trans gauge, boost gauge, plastic to fab up my gauge mount, LC-1). I'm now waiting on my custom Nordskog AFR gauge to go with the LC-1. I plan on building my gauge mount out of some of the plastic and installing the gauges above the single DIN Pioneer head unit.
The last thing I have to figure out and order is the fuel upgrade and whatever piggybacks I'm going to use.
After my exhaust bung debacle I'm taking a week off from this thing.
I'm pretty sure I can install the SC, but I may see if there's anyway I can have it done at a local dealership, and "help" with the install so I can learn how it's done (and shoot a few pictures). There's a pretty good dealer here that's done some of these, but they charge $530 for the install (ouch). Might be worth it for the 18 month remaining power train warranty though.
