Spark plug question
Old 07-06-2009, 04:08 PM
Bird333's Avatar
Spark plug question
Vehicle: '98 4-Runner 4-cyl.
Do I need to use the metal gasket that comes with the sparkplugs I bought?
Also the manual mentions a 16mm plug wrench/socket, do I really need to get this or will any plug socket generally work?
Thanks!
Old 07-06-2009, 08:22 PM
scuba's Avatar
Metal Gasket ??
Uhh never heard of nor seen a metal spark plug gasket..
Any pics ?
And I think when I just did my plugs I used a 5/8" from vatozone
Old 07-06-2009, 08:31 PM
Whitey13's Avatar
he must mean the washer
Old 07-06-2009, 08:43 PM
Elton's Avatar
dont forget the anti seize
Old 07-07-2009, 05:28 AM
stir_fry_boy's Avatar
The metal gasket should come with the plugs.
Old 07-07-2009, 06:09 AM
Bird333's Avatar
Yeah, I mean the washer. So I do need to use it then?
Old 07-07-2009, 06:48 AM
hross14's Avatar
Yep-you do--and anti seize as mentioned above
Old 07-07-2009, 10:10 AM
Do not gap, take the plug out of the box, remove the cardboard over the electrode, put on anti seize and put in the engine just the way it is.
Old 07-07-2009, 10:23 AM
bgmac's Avatar
He needs to set the gap!
Old 07-07-2009, 10:29 AM
camo31_10.50's Avatar
my plugs are 13/16ths..lol..and ONLY 13/16ths plug wrench will work...o well
you can check the gap of the plugs..i can almost gurantee you that they are already the correct gap....i always check mine just in case..and i've never found one that was wrong..lol
Old 07-07-2009, 10:34 AM
bgmac's Avatar
Are you talking about oem plugs??
Old 07-07-2009, 10:51 AM
Don't know about the 4 cyl engine but at least in the 5vz-fe engine, you only use dual grounded electrode spark plugs. I don't know if the 4 cyl has them or not. But now-a-days you rarely need to gap plugs. I can't remember the last time I gapped plugs.
Old 07-07-2009, 11:09 AM
bgmac's Avatar
Im Running the NGk-R BKR5EKB Dual electrode spark plugs. Gap calls for .044
http://www.amazon.com/gp/product/B00...B0KVDKP5ZZF0H3
Old 07-07-2009, 11:16 AM
You don't gap those. If you do, you ruin them. The distance between each of the grounds has to be precisely the same. If not, only one ground instead of two will work and you might as well put $2 platnium single gounded plugs in it.
Old 07-07-2009, 11:27 AM
i've tried about 10 different styles and brands of spark plugs...none seemed to be any better than the cheapo depo ones from oreiley's..so i use them..why spend a crap load on 4 name brand or whatever plugs...when u can spend just a few bucks on some cheap plugs that do the EXACT same thing...........
Old 07-07-2009, 11:33 AM
waskillywabbit's Avatar
Use OEM plugs as they come out of the little box with some anti seize.
16mm is 0.629 and 5/8 is 0.625
Old 07-07-2009, 11:37 AM
bgmac's Avatar
Pains me to say this...you are correct! Just got off the phone with NGK and he confirmed it. Looks like im putting in some new plugs today! lol
Old 07-07-2009, 12:53 PM
hross14's Avatar
Just an FYI--the only reason Yota used the twin ground electrode was because of the wasted spark ignition system--it fires the plugs twice as much--i.e...two electrodes.
I am running iridiums--i guess just because......
Old 07-07-2009, 01:11 PM
Whitey13's Avatar
Single electrode? I just pulled mine and they were denso iridiums(single)
Old 07-07-2009, 04:25 PM
bgmac's Avatar
Well, at least Toyota hooked me up for free!
Quick Reply: Spark plug question
