Spark Plug gapping
Old 10-23-2007, 10:06 AM
tigre's Avatar
Spark Plug gapping
I have 2000 4runner with 3.4 engine on it. I am gonna change the spark plugs and i bought some Denso 5062 Copper Spark Plugs. The problem is that i dont know how to properly gap them since they have triple electrodes. So does anyone know how to adjust eh gapping on these or should i just install them how they are. Any help will be appreciated.
here's a pic
Old 10-23-2007, 10:24 AM
Nate08's Avatar
Quite a few spark plugs are already properly gapped out of the box. My new Bosch Platinum Dual Electrodes are already gapped to the right measurment.
Old 10-23-2007, 11:44 AM
Bennito's Avatar
use a wire gauge not a flat blade. still will have problems, but as far as I know, the best way to check. (i say check because the prior comment is correct that often times plugs are pregapped. but i always like to check)
Old 10-23-2007, 11:51 AM
OSU4Runner's Avatar
Most of the triple and quadruple electrode plugs are already gapped. I think you're only suppose to use dual electrodes on the 3.4 though. It says it right on the engine.
Old 10-23-2007, 04:13 PM
urbanj's Avatar
don't count on the plugs coming pre gapped. ALWAYS check them. Just the other day I had a set of plugs for a Ford come and one set was good and for the other bank all the ground straps were bent down. some even bent the platinum center electrode. the packaging looked fine.
You never know who is going to drop your parts. ALWAYS CHECK THEM.
Old 10-23-2007, 04:34 PM
Lone4runner's Avatar
Thought i read somewhere that you are not suppose to gap the double, triple and quadtruple electrodes.
Old 10-23-2007, 04:40 PM
OSU4Runner's Avatar
I know you're not suppose to gap the quadtruple, not sure about the other two
Old 08-10-2014, 06:57 AM
XPY
XPY's Avatar
Gap: 1.1 mm (0.043 in.)
Old 08-10-2014, 05:22 PM
Staff
DeathCougar's Avatar
No need for off topic ridiculousness. And don't antagonize someone then report his retort, Arnezie.
XPY Digging up old threads is usually not the best idea, but we appreciate any time we get real tech input into the threads that don't have solutions/answers.
Move along, nothing to see here folks
Old 08-10-2014, 05:30 PM
rworegon's Avatar
An Advanced Search under Tools (this works much better than the Search box on the main page) of: 3.4 spark plug gap
yields this 2010 thread with the requisite gap information for the dual electrode plugs in post 14 and 15:
https://www.yotatech.com/forums/f2/n...gapped-191407/
Old 08-15-2014, 10:15 AM
Potomacduck's Avatar
My factory dual electrode plugs from Toyota are supposedly gapped, but they aren't.
Use a wire gap tool, not a flat blade....and DON'T forget the anti-seize on the threads!
montanatruck
02-26-2017 07:07 AM
raptor510
02-17-2017 07:11 AM
raptor510
08-19-2015 02:15 PM
defrag4
07-31-2015 10:50 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: Spark Plug gapping
