Snow between Cab and cap
Old 12-01-2005, 03:17 PM
nermalgod's Avatar
Need some help. Had the third snowstorm of the season and found for the third time that snow had filled in between my extended cab and my Century topper.
I need a solution to keep snow out of here that doesn't involve adhesives as the cap is being returned. I thought I could pull the cap away from the cab and then squash some pipe insulation above the window. Anyone tackle this problem and come up with a good solution?
nermal
Old 12-01-2005, 03:29 PM
Elton's Avatar
how much of a gap are we talkin about ?
Old 12-01-2005, 03:39 PM
Flamedx4's Avatar
anything wedged in there will chafe.
Old 12-01-2005, 03:44 PM
86toyota's Avatar
Ok this is going back a few years, but my Grandfather always used one. It was an inflatable ring that went between the cab and cap. Think of it as a 3-5" Dia. rectangular inner tube. It was designed so you could open the truck & cap windows with a seal between them. Wonder if they still make them?
nermalgod's Avatar
Something like half inch.
Yeah, I'm concerned about rubbing.
Old 12-01-2005, 04:05 PM
nermalgod's Avatar
86toyota
Yeah, donuts are still being made. I was hoping for a cheap solution. I also haven't heard many good things about them.
nermal
Old 12-01-2005, 04:11 PM
Elton's Avatar
dont the make a weather strip kit for canopys
Old 12-01-2005, 04:12 PM
waskillywabbit's Avatar
Park indoors or move south for the winter.
Old 12-01-2005, 04:13 PM
rngrchad's Avatar
Nermal, I've got the same situation w/ my topper. It doesn't seem to hurt it any, however when the snow melts, it leaks into my bed.....ahh well. Good luck man.
Ps...WISH for snow!
Old 12-01-2005, 05:10 PM
Elton's Avatar
what my freind did was get some intertubes for those truck tires places and cut it in to strips it was was to short soo he glued it to togother and cut holes at the end and put a bunge cord at each end and tied it of to a spot under the truck
Old 12-01-2005, 05:15 PM
nermalgod's Avatar
Elton
Say again?
rngrchad
I'm not worried about the snow sitting there, only that I cannot see through the window. I like having rear visability. If I can find a decent job where snow falls every day, I'm there.
nermal
Old 12-01-2005, 05:19 PM
Elton's Avatar
sorry what he did was he got those big truck intertubes and cut it and ran it over top of the cab/cap and down the sides to keep the rain out of the truck
Old 12-01-2005, 06:48 PM
nermalgod's Avatar
hmmm . . . sounds too ghetto for my rig.
Old 12-01-2005, 07:10 PM
SnoViking's Avatar
you could do 2 sets of weather stripping. One on each half of the seam that over lap. (ei: 1 piece attached to the cab and 1 piece attacthed to the cap) have the pieces over lap in the center... this will still allow for the 2 pieces to flex and move but the only thing that rubs would be the weather stripping it self. then you could just peel off the stripping on the cap when it goes back... heres the pic in thinking
pat
Old 12-01-2005, 07:34 PM
Godzilla's Avatar
how about some duct tape?
can even get classy with some red duct tape?
Old 12-01-2005, 08:01 PM
Godzilla's Avatar
or maybe something like this;
http://www.lundlook.com/lund_truck_p...al__truck.aspx
its pretty much just weatherstripping but looks pretty thick. there is adhesive tape but im sure it would come off easily.
or how about the window deflectors for trucks. althought they are plastic so that may rub.
Old 12-02-2005, 04:51 AM
tc
tc's Avatar
My Innovation shell on the '89 had a long piece of weatherstripping that attached to the opening (just snapped over the edge of the 'glass) and kind of flared out and sealed to the back of the cab. Maybe they have something like this at a truck accessories place or where you got the cap...
Old 12-02-2005, 06:58 AM
rockota's Avatar
If it's being returned, why do you need a solution? Remove the cap, return it, all solved.
Old 12-02-2005, 07:21 AM
Flamedx4's Avatar
I had a Brahma that had the rubber seal like that. It rubbed all the paint off the back of the truck cab.
Old 12-02-2005, 05:48 PM
nermalgod's Avatar
rockota
It's being returned to be replaced by another camper shell. If they cannot rectify the problem, then I am going to get an ARE or LEER topper that I am sure will have similar problems.
nermal
Quick Reply: Snow between Cab and cap
